Televison & Video Logo
V
Valentina Posted on Nov 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sometimes, my Telefunken TV, have some troubles with audio, such as: it's impossible to hear more. This fact happens in different time, you can not predict when it will happen again. The problem occurs every three or four days, or once a week, sometimes even twice a day. To continue listening I turn off and on for a few seconds the device. Thanks for your help.
wade dunlap
Level 2:
Scholar:
  • Expert 101 Answers
  • Posted on Nov 01, 2013
wade dunlap
Expert
Level 2:
Scholar:
Answers
101
Questions
0
Helped
30651
Points
298
Is it an old tube type tv? my step dad still has one...only reason is cause he has the sound directed into a home theatre system from the direct tv box... the volume on the tv sucked even from day one but now It doesnt work at all.. ever...
If its an old tv, it may just be dieing, if its not that old, then I dont know. sorry
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Oct 25, 2006
SOURCE: black box on screen
On your remote should be a button called TV caption or text. Turn off the closed caption as someone hit it and turned it on by accident. If its not on your remote, then it is in the menu. Good Luck Ps Please dont forget to rate this thread.
Anonymous
  • 3130 Answers
  • Posted on Jun 05, 2007
SOURCE: The stand by timer flash 9 times stop and start again
you have a regulator problem my friend in the power supply or there is a fault in the G board. This is not a repair an untrained person should attempt, please get a pro to assist you in this repair.
Anonymous
  • 6 Answers
  • Posted on Jun 25, 2007
SOURCE: tv wont turn on
try to re solder the power suply
Anonymous
  • Posted on Oct 25, 2007
SOURCE: SONY - TRINITRON 26" TV (PICTURE TUBE TYPE)
I have the exact same problem! I'm assuming it's time for a new tv.
Anonymous
  • 372 Answers
  • Posted on Nov 11, 2007
SOURCE: DLP tv trouble shooting
Hi.
Yes it could be a cooling problem, If your tv has any filters remove & clean them ensure fan can turn freely & that nothing can or is snagging it.
http://dysonmanuals.inc.io/
Chris.
2answers
Can't hear the sound on a VR 18+ game, although the video feed is ok.
See if your sound cable is connected properly, and that it doesn't malfunction. Similar trouble, but I've found it only happens when using bluetooth via the immersive bundle earphones. When I plug in the cord to the earphones, the trouble is gone... so it only seems to be bluetooth. Even happens on pandora sometimes. I'm trying to replicate the trouble to see if it's the VR earphones.
I've tried a lot of different virtual reality experiences, like those 9 VR Sites. Some good, some extraordinarily amazing, and some terrible. But mostly good. I've never, however, tried 18+ VR. So when Naughty America, one of the U.S.'s largest x-film production companies, invited me to try out 18+ VR for myself at CES, I wasn't sure what to expect. Would I merely be a spectator in a room watching people get freaky? Or would I actually be having a good time with VR?
What is wrong with th sound on my tv. Toshiba 42"
sometimes its the hdmi cable input
to trouble shoot that switch to another type of input . like video an audio cables or channel 3/4
if it still happens then the audio circuit in tv is to blame.
My flatscreen tv is flickering and audio sometimes doesn't work. the screen goes black sometimes and when that happens the audio doesn't work
maybe your tv is old. If your tv was from goodwill or you had it for a long time....that might happen.if ya just bought it from a store that is not like goodwill nvm.
4answers
Telefunken Vegas Tv + All For One Universal Remote = :(
Codes to check are 058,038,049,026. If you wish to get more details to different brands of universal remote controls, check this link.
I have a LG 50PC1DRA 50 in. plasma tv, and recently it's been experiencing an odd problem that I can't find the answer for. Randomly, the screen will start flashing. The image on the tv will r
Look for any loose contacts in power outlet, RC jack, cable and socket. If you have the same problem even when using different input devices, the TV needs servicing.
4helpful
I moved apartment and now expat shield is unable to connect, any suggestions?
Sounds weird. Is your internet line working ok otherwise? The fact you moved apartment shouldn't make any difference to Expat Shield. Two possibilites - their server is/was down, which is not unlikely. Secondly, did you kill the page it jumps to when it connects? Let that load properly first then kill after. I usually have my TV page up ready to go, connect Expat, let it open what it wants then kill it and refresh tv page.
They may even have updated something and you might need to install a newer version to connect. It has happened before.
Most likely server trouble, which then sometimes leads to necessity for new install. Probably purely just a coincidence with your change of apartment :-)
1helpful
Background music is unbearable on TV - almost impossible to hear dialogue
I had a similar problem.. What's needed is to change the audio mode of the tv.
You may need the original tv remote to access it's setup menu or maybe able to do it with onboard buttons. (not the channel setup, but the screen brightness and hue and other stuff - Audio setup)
When entering the audio setup, you may find you're in surround sound or some other "type" of sound processing. Maybe simple Speech mode will suit you. Try different modes till you find a happy medium for your own taste.
I can hear audio in before logging but when i log in no sound
I would check your device manage to see if your audio drivers are installed. sometimes you will hear sound if it is turning on but if the software is not installed it wont work properly after turning on. All CPU's are different.
The audio and video are not in sync
Are the movies you're watching store purchased DVDs? Sometimes with downloaded movies, the audio and video are just out of sync.
If they're store bought, it's possible that you've got a delay set in your receiver. Consult your receiver's operating manual to see if there's a "delay" option.
It's also possible that you're hearing that delay in the TV speakers.
If you've got the audio coming through the receiver AND the tv, you'll hear a slight delay when the audio's traveling from the DVD player to the television itself. This could happen "sometimes", if the tv volume is on, and not happen when the tv volume is off.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
