Computers & Internet Logo
D
Dave Raymond Posted on Oct 31, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I type r on my keyboard the run command box pops up, when I type other letters different things pop up. I have to restart my computer to get it to stop. Is there a better way?
mikadot
Level 3:
  • Master 2,113 Answers
  • Posted on Oct 31, 2013
mikadot
Master
Level 3:
Answers
2113
Questions
0
Helped
465769
Points
5959
Your windows command (between CTRL and ALT) is stuck. I am assuming that you or someone else spilled some sugary substance on the keyboard. To clean this... dismantle your keyboard and use a toothbrush (preferably the dogs :) ) and some water and a drop of dish soap and scrub and rinse anywhere that food contaminated. Let it dry for a few hours and then put it back together.
5 Related Answers
Anonymous
  • 113 Answers
  • Posted on Mar 30, 2007
SOURCE: Mouse stops responding randomly
The issue may not necessarily be with the mouse. Are you able to use the keyboard once the mouse freezes? If you not even able to use the keyboard, there is some application installed on your computer or a virus due to which the mouse freezes. If, in case, the keyboard works even though the mouse is stuck, try changing the USB port or try a different mouse. Please revert back with any other observations. Good Luck
A
Anonymous
  • Posted on Oct 06, 2007
SOURCE: multiple letters typing at once
goto control panel/keyboard and check the character repeat settings.
teknowolf
David Preston
  • 207 Answers
  • Posted on Nov 06, 2008
SOURCE: Microsoft wireless optical desktop 2000 - keyboard and mouse
There are a number of things that may be causing your problem.
The first thing I would check would be the batteries, with these units having a wireless connection if the batteries become weak they will transmit a weaker signal and thus make it harder for the unit to read. Battery life is variable depending on how often you use your keyboard and mouse, and how far away from the transmitter the keyboard and mouse sit.
Also because the units are wireless there may be interference coming from other wireless devices in your household. Some possible guilty devices maybe cordless phones, Wifi adapters, and even some remotes.
Also Have you installed the intellitype and Intellipoint software for your Mouse & Keyboard. If so you can use it to check your battery life/ signal strenth and set you mouse sensitivity and type repeat rate.
On the bottom of your keyboard & Mouse and on the top of the wireless transponder there are reset buttons. Pushing the transponder 1st and then either or both the mouse and keyboards buttons should resysnc them without the need for a reboot.
Hope this helps
Dave
Anonymous
  • 329 Answers
  • Posted on Oct 03, 2009
SOURCE: My grandbaby hit all kinds of buttons on my
unplug the keyboard and replug......if it doeasnt work try resetting bios
Anonymous
  • 120 Answers
  • Posted on Dec 26, 2009
SOURCE: Advent wireless keyboard keys do not show the
what OS are you using?
anyway here is a link that will show you the instructions for your OS
http://www.conversationexchange.com/resources/keyboard-language.php
Change password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
tip
How to restart or shutdown a computer through a remote desktop connection
When you are connected to another computer by remote desktop, did you ever notice that the shutdown and restart options are not there. The computer that you remote desktop to must already be on. But if you regularly use remote desktop, at some stage you will want to restart the remote computer from where you are. For example you might install a program and you need to restart the computer to finish the installation. If this doesn't happen automatically then you can follow the steps below.
How to Reboot or Shutdown a Machine from Remote Desktop Connection using Windows XP?
  1. Open the run box by pressing the WINKEY and the letter R on the keyboard.
  2. Type the following command into the run box: shutdown -r -f
  3. Press Ok.
  4. This will restart the remote computer.
If you would like to shutdown the Windows Xp remote computer you can type: shutdown -f
When you are typing these commands in you must type it exactly right. If you miss a space or a dash it will not work.
Restart a remote computer using Windows Vista or Windows Seven.
On these newer operating systems the run box is almost obsolete. You only have to open the start menu and type these commands into the search bar at the bottom. This area acts as a run box and you can type commands into this.
on Jan 29, 2010 • Computers & Internet
I need to fully re-install Windows XP, no matter to lose any information on hard disk, I am using my Windows XP CD and the first device for boot is set to be the CD, but I get Boot Manager missing any way....
Step 1:
Open your anti-virus software program and run a full scan on your computer. Delete all quarantined and infected files when the scan is complete. Insert your Windows XP Install CD into your computer's CD/DVD-ROM drive. Restart your computer. Press the "R" button on your keyboard when the screen says "Welcome to Setup." Type in the admin password when prompted. Press "1" and then "Enter" to open the command prompt. Type "fixboot" into the command prompt. Press "Y" when a pop-up box appears, asking you for confirmation. Restart your computer and you should be taken to your desktop.
I let the HP asst. Install a bios update and the install is stuck at 40%. What can I do to get out of the update?
Turn on the computer and begin hitting the "F8" key when you see the BIOS screen.
This will take you to the Safe Mode menu.
Use the arrow keys to highlight "Safe Mode," then hit "Enter" on your keyboard.
This will boot your computer in Safe Mode, a minimalist manner of operating Windows that runs only essential Windows files.
If using Windows XP in Safe Mode, click the "Start" button and then click "Run." In the box that pops up, type "msconfig" and hit "Enter."
If using Windows Vista or Windows 7, click the Windows logo in the bottom left corner of the screen, type "msconfig" in the search field and then hit "Enter."
This will open the System Configuration Utility.
In the System Configuration Utility box, click the "Services" tab, check the box that reads, "Hide All Microsoft Services," click "Disable All" and then click "Apply."
In the System Configuration Utility box, click the "Startup" tab, click "Disable All" and then click "Apply." Next, click the "Close" box.
A box will pop up that prompts you to restart your computer.
Select "Restart" and let the computer restart itself, allowing it to boot to Windows normally.
If the computer still stalls when trying to boot to Windows, restart the computer and boot to Safe Mode again.
Run your antivirus program in Safe Mode, deleting any files that are flagged as viruses, spyware or malware. Restart the computer and boot to Windows normally
hope this helps
1helpful
Bootmgr is missing
If you use the vista,follow the bellow step.
SOLUTION 1
- Get your Vista installation DVD and pop it into your drive.
- Then restart your computer.
- Set your computer to boot from DVD or CD in your BIOS.
Vista will ask you for language and keyboard layout information, after which you will be asked if you want to re-install Vista
or repair your existing installation.
Select Repair. After which Vista's System Recovery Tool will start.
Select Startup Repair and let Vista do its thing! That really is all there is to it!
If that doesn't work try this:
SOLUTION 2
If the previous method does not resolve the problem, you can rebuild the BCD store by using the Bootrec.exe tool in the
Windows Recovery Environment. To do this, follow these steps:
- Press a key when you are prompted.
- Select a language, a time, a currency, and a keyboard or another input method, and then click Next
- Click Repair your computer
- Click the operating system that you want to repair, and then click Next
- In the System Recovery Options dialog box, click Command Prompt
- Type bootrec /rebuildbcd and then press ENTER
• If Bootrec runs successfully, it will present you with the installation path of a Windows directory. To add the entry to the
BCD store, type Yes . A confirmation message appears that indicates the entry was added successfully.
• If Bootrec cannot locate any missing Windows installations, you must remove the BCD store, and then you must
re-create it. To do this, type the following commands in the order shown below: (Remember to press ENTER after each
command)
bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
bootrec /rebuildbcd
- Restart the computer.
Or can watch the video
http://www.youtube.com/watch?v=NWf1orrx8Ok
Hope this helps.
Shibuda,
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
1helpful
The message come up saying "BOOTMGR is missing".
Hi r_durley,
Based on your situation. I suggest trying the following steps:
Step 1:
Vista will ask you for language and keyboard layout information, after which you will be asked if you want to re-install Vista or repair your existing installation.
Step 2:
If the previous method does not resolve the problem, you can rebuild the BCD store by using the Bootrec.exe tool in the Windows Recovery Environment. To do this, follow these steps:
• If Bootrec runs successfully, it will present you with the installation path of a Windows directory. To add the entry to the BCD store, type Yes . A confirmation message appears that indicates the entry was added successfully.
• If Bootrec cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order shown below: (Remember to press ENTER after each command)
bootrec /rebuildbcd
Hope it helps.
Best regards,
Reyjoshua07
Keyboard trouble shooting
Check by swapping the keyboard. You might have a stuck windows key (the one with the windows flag on it)....
1helpful
3answers
Trying to boot up a toshiba laptop and getting message BOOTMGR is missing press Ctr+Alt+Del to restart. !!! help!!!
SOLUTION 1
SOLUTION 2
bootrec /rebuildbcd
2answers
BOOT MGR MISSING
Rebuild the BCD store by using the Bootrec.exe tool If the previous method does not resolve the problem, you can rebuild the BCD store by using the Bootrec.exe tool in the Windows Recovery Environment. To do this, follow these steps: 1. Put the Windows Vista installation disc in the disc drive, and then start the computer. 2. Press a key when you are prompted. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. Click the operating system that you want to repair, and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type Bootrec /RebuildBcd , and then press ENTER. • If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type Yes . A confirmation message appears that indicates the entry was added successfully. • If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command. Bcdedit /export C:\BCD_Backup ren c:\boot\bcd bcd.old Bootrec /rebuildbcd 8. Restart the computer.
Keyboard problem
Did it originally have a Japanese Keyboard? Maybe the Keyboard you installed is bad or the numlock or some other function key is enabled???
Grand Canyon Tech
Grand Canyon Tech
