Dear Vincent,
The 0A-0224-0000 is a "File Copy Failed" error. It means that either the computer was not able to read from the CD/DVD or it finished reading from one CD/DVD and was expecting to read data from the next one (when you have two or more recovery CDs/DVDs). If you have more than one recovery CD/DVD, as soon as you see the CD/DVD reader LED (light) stop flashing, eject the CD and insert the next one in the sequence, doing so till all recovery CDs/DVDs have been read.
If you cannot eject the DVDs by pressing the eject button (some DVD writers only allow you to eject the disc after finishing the whole operation) you will have to straighten up a paper clip and insert it in the small hole close to the eject button to force it open and change the CD or DVD (do a Google search for "how to open a CD or DVD drive with a paperclip, in order to better understand how to do it)".
Hope this helps!
SOURCE: The HD I put in my Toshiba Satellite A135 did not
I have come across a similar problem when restoring a Dell laptop with Windows Vista. There is an option on the recovery disk to install drivers. Some computers that have SATA harddrives need the driver loaded before you can load the O/S back onto the computer.
Once I did this, it sailed right thru installation.
SOURCE: hi,i have toshiba laptop setlitte a 205 .i dropped
You bought a new hdd drive that seems working good, Hdd (Hardisk Drive) is connected to a port that is also connected to the motherboard, in this case that port is no longer stable possible cause of the accident, you need to replace that port to fix or to identify the problem. This hardware device is really sensitive thing, you need a personal technician to troubleshoot the problem if you're not familiar with this device
SOURCE: After being prompted to install the 2nd recovery
Welcome to Fixya
You only have two problem there it might be your CD rom drive is intermittetly reading disc or you have a bad media disc. Try to clean the Cd rom first using a disc cleaner. You can also clean the disk by using a lint free cloth. If your CD rom can read all of your cd's then you have a bad media disc. You can request for recovery disk with Toshiba tech support.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: I have a satalite 300
try using ActiveBoot suite v5.0.5, when turnig on your computer. This program will scan your computer and show u all the errors,missing files, wrong dll,...and repair them. It worked very well for me as I had a TROJAN virus on my Toshiba satellite 300 and couldn't even boot anymore.
After that try use the RegistryBooster tool witch solves every windows problems.
I hope this will help. Good luck :)
