Question about Sony CDX-GT210 CD Player
Unresponsive buttons on Head Unit - Help!
I have owned a CDX-GT210 Head Unit for the best part of a year and have had no problems with it, until now! A small selection of buttons to the left hand side of the head unit as you face it have simply stopped working. I have not knocked it, dropped it or has it suffered any form of 'trauma'. The Unit itself works without a problem, and i can listen to CD's, changing volume, skipping and scanning tracks etc with no problems with sound quality, speaker and/or amplifier issues. But it is only CD's i can listen to. In literal terms the following buttons dont respond when depressed; source, mode, EQ, pty, off and the push activation on the volume turner for bass, treble, fade, etc. Basically all the push buttons to the left of the unit dont respond when depressed, although they do make the 'click' when depressed and none are loose. Can this be fixed or diagnosed by me? Could it be a loose connection somewhere? Do i need a new head unit entirely or can the fascia be repaired?... help! Anything help you can offer would be greatly appreciated. Regards James
    New Friend:
I got Sony Cdx-GT340 after 3 years my buttons stopped working, the reset button didn't work, other suggestion was to use cotton swab with little alcohol to clean contact, at first I cleaned but it still wouldn't work, so having nothing to lose, I really saturated swab and freely used it on male connector and quickly shoved it into female connector -- and voila!!! it start working!!!!!!!
Posted on Oct 02, 2013
I have the same problem and i can figure it out either
Posted on Feb 28, 2008
  • Anonymous Feb 28, 2008
    can't sorry, i can't figure it out
SOURCE:
Wireing diagram sony cdx-gt210
Sony CDX-GT210 repair manual includes the wiring/connection diagram. If you want the copy, click here.
Jdvillanueva
Oct 11, 2011 | Sony CDX-GT210 CD Player
Sony CDX-GT210 Can't find the reset button. Radio plays fine, but No sound comes out when I use CD player. Panel displays that it is able to read disk (numbers for time played goes up and displays...
Usually Reset button located underneath front panel, remove front panel and look at unit, hopefully you will see reset button, press it with some pointed thing like paper clip etc to reset the unit.
Thanks.
Aug 11, 2011 | Sony CDX-GT210 CD Player
Just purchased a car for my daughter and it has a sony cdx gt210 player. No instructions, how many cd's can be loaded one or more?
Hi steve
To answer your question;
You can download the owners manual by clicking HERE
It has everything you need for info.
Hope this help
Cheers
Jun 03, 2010 | Sony CDX-GT210 CD Player
How do you set the clock?
The Clock on this unit uses a 12-hour digital indication.
1.) Press and hold the SELECT button. (The setup display appears.)
2.) Press the SELECT button repeatedly until "CLOCK-ADJ" appears.
3.) Press SEEK +. (the hour indication flashes)
4.) Rotate the Volume Control dial to set the hour and minute. (To move the digital indication, press
SEEK -/+)
5.) Press the SELECT button. (The setup is complete and the clock starts.)
To display the clock, press DSPL. Press DSPL again to return to the previous display.
If this helps, please leave rating!
Oct 11, 2009 | Sony CDX-GT210 CD Player
I need to know how to reset my cd player
I have the Sony CDX-GT200 unit personally. On my unit, after you remove the faceplate, there is a reset button towards the left of center on the head unit itself. However, I don't see it pictured in your models Owners Manual. Here is a link to your manual.
http://www.docs.sony.com/release/CDXGT210.pdf
Here is a link to my manual for illustration purposes only. Look on page 4.
http://www.docs.sony.com/release/CDXGT20W_200.pdf
Hope this helps.....
Had to have my battery jumped and since then I do not have power to my sony cdx gt210
pull the unit out of the dash if applicable and inspect the rear of the head unit(deck) there should be a mini fuse in the back of the unit or inline with your power supply to the deck sounds like you just blew a fuse
May 08, 2009 | Sony CDX-GT210 CD Player
Sony CDX-GT210 CD Player not working all of a sudden
remove the unit and the reset button should be a small pin hole on the back!
hope this helps
alex
Apr 06, 2009 | Sony CDX-GT210 CD Player
On a Sony CDX-GT210, where is the reset button?
To eject the cd, try disconnecting the harness then plug it back in it should spit it out. As far as the reset, I have the same deck, and have not seen one. It either doen't exist or is hidden very well. Maybe download the manual PDF online and check that.
I cant change the time?
Download User Manual of CDX-GT210 from Sony Support and go to Page-4 for clock setting detailed procedure.
Nov 10, 2008 | Sony CDX-GT210 CD Player
Sony CDX-GT210 CD Player Logo
452 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
