I recently purchases a new dodge truck with sirius satellite radio factory installed. The problem is my camper covers the antenna that is mounted on the top of my cab. Can I install a FM antenna to eliminate the need to run cables to the outside of the truck. Or shall I install a seperate antenna? Can I have 2 antennas? thanks
You will need to get another sat antenna, and locate it somewhere either above the camper, or where the camper does not obstruct the antenna. Any store that sells sat radio equipment (Fry's, Best Buy, etc) will have the micro antenna. Install it either on the hood of the truck, or on top of the camper. You will need to run the antenna to the rear of the dash. They make Y couplers that will allow you to run both the OEM antenna and the extermal antenna at the same time, and it will not hurt the system to have both wired in at the same time.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kenwood SIR-KEN1 SIRIUS Radio
It no longer receives dab this has been happening before the switch over.It comes on by itself and...
(More)
It no longer receives dab this has been happening before the switch over.It comes on by itself and starts searching for stations
i have 3 s50's 1 of them says low battery on any dock or as a portable an shuts off .the other one...
(More)
i have 3 s50's 1 of them says low battery on any dock or as a portable an shuts off .the other one works gerat on any dock **** as a portable says dead battery.when either of them are on any dock it shows dead battery .now the 3rd works great in any dock and with all 3 batterys all have updates can you dont want buy new unless bubba is coming back exclusive to sirius
i have a satcruiser reciver dsr-101. i was in the menew and i pushed wrong key and my picture on tv...
(More)
I HAVE A SATCRUISER RECIVER DSR-101. I WAS IN THE MENEW AND I PUSHED WRONG KEY AND MY PICTURE ON TV IS ROLING FAST. AND I CAN NOT EVEN OPEN MENEW BECUSE IT IS ROLING FAST,WOULD YOU PLEASE LET ME KNOW HOW I CAN FIX THAT
can anyone help when i plug my eurovox 2006 in all it does is lines go across screen on box then...
(More)
can anyone help when i plug my eurovox 2006 in all it does is lines go across screen on box then nothing at all was working perfect 2 days prior
