-   trying to connect to ps3 does not pick up ip address any solution-   homer22
Jan 04, 2008
-   do you have to disable the onboard antenna on the w200 pcb? i purchased
an add on antenna|| http://www.data-alliance.net/servlet/the-4/Antenna-7dBi-Magnetic-OMNI/Detail#itemadded modded the case a little. but when i connect the mc
connector. i don't see any improvement on reception through network
stumbler. if anything i believe that it actually gets worse. what
antenna setup does it use when stock.
thanks in advance-   number240
The easiest solution is to purchase a range extending antenaa($39.99) found at various electrnoic/computer stores. If you need more range (1000ft or more) you can purchase power extenders($149.99) these will send your signal throu your house AC lines.
you can boost it, what is thev distance b/wn ur router and the laptop , is it more than 30 feet?, if not change the channel in the router, or upgrade latest software in the router and that would fix the problem, if u still have the same prblm, u can go for a range extender..
my computer does not detect wireless in my own house.it states that there none in range.when i...
(More)
my computer does not detect wireless in my own house.it states that there none in range.when i change setting and ask windows to detect,it does not find it and when i insist my computer freezes.I operate XP
I have lost the instalation CD-ROM for my Wireless G Notebook card. Is there any other way to insall...
(More)
I have lost the instalation CD-ROM for my Wireless G Notebook card. Is there any other way to insall it?
When it instal up 80% then it ask plug in network card, I push net work card slightlit on card...
(More)
When it instal up 80% then it ask plug in network card, I push net work card slightlit on card flush then nothing? it does not go any further.
I bought a belkin 802.11g wireless card and i have the belkin cd software to install in my laptop i...
(More)
I bought a belkin 802.11g wireless card and i have the belkin cd software to install in my laptop i set it up and now when i tried to be connected to internet it says is an error cannot be connected. I don't know what is it, I don't know what i did wrong, I need step by step how to install and have internet in my laptop. Can you please help
