Question about Whirlpool Duet GHW9150P Front Load Washer
FH code had been intermittant, now occurs with every load. Have been through the steps suggested by jtfix for that code. Went through the service tech sheet that comes with the machine and ran the diagnostic test in it. Get the FH code at C:01 and C:03 indicating either the flowmeter or inlet valves for cold and hot? What is the best course of action from here? What is the common problem in this type of issue? I don't want to just replace parts without reason, I'm trying to do this the smart way... I went to my local appliance sales/parts/service center and ask for guidance before placing an order for parts with them, only to get talked down to and pretty much told that they would not help me in any way - they want to make service calls rather than customer service. I don't want to sound cheap, but I have not been impressed with service repair companies in the past.
  • actionmarine Oct 05, 2007
    Replaced the flow meter and the inlet valve. Problem solved and clothes clean again! Thanks for the sound advice - will most certainly recommend!!!
  • cajunpapa Nov 13, 2007
    I have this problem but only when I try to use hot water only but hot water is going into washer but then it stops and gives me FH code. we don't have this problem when we use warm water (hot/cold). and where can I get paarts to fix it.
  • 878 Answers
Marine, In usually all cases I find this to be the flow meter causing the error. You can check the inlet valve at the main board. Remove the top, It will be the 4th harness from the right looking at it from the front. On the harness from left to right the first two wires will be the hot water solenoid, should read 800 ohms. The second two wires will be the cold, should read the same. If the inlet valve checks good, I believe that the flow meter is causing the problem. Catriver.
Posted on Oct 01, 2007
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
The error code FH means no water is detected entering the machine which can be due to a faulty flow meter not registering the correct amount of water that has passed through it or the pressure is not tripping from the empty position to the full position when the correct water level has been reached. Your machine is definitely made by Whirlpool like other Kenmore and Maytag washing machine so they are basically the same and troubleshooting is then the same. The link below contains the detailed troubleshooting of this error code for a Whirlpool Duet and should be applicable to your machine.
Error Code FH on Whirlpool-made Front-Load Washers
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have a Whirlpool duet machine with an intermittent F06 code coming up at the moment. The history... About a month ago I had to deal with an F02 code relating to a very clogged filter. Cleaned that up...
wow i like a customer who has done their homework :) based on all you have checked,if i were in the home, as the technician would recommend to you to have the drive motor replaced since the biult in tachometer isn't telling the mcu what rpm's it has spun at
Aug 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
FH Error code Whirlpool Front load washer. I
the only thing you can do is to go to the manufactures website and download the user manual and check the trouble shooting guide for a possible cause for this problem eric
Jan 17, 2018 | Whirlpool Duet GHW9150P Front Load Washer
Washing maching flashes F H on time display
The FH code indicates a fill failure. The problem can be with the fill valves, flow meter or the pressure switch. This error occurs if the control doesn't see the flow meter turning. This usually a fault of the flow meter but be sure both the hot and cold water valves are working. Try a hot water wash cycle and confirm that hot water is coming into the washer. Check both valves and if they are working the problem is most likely the flow meter.
Also the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Please get back to us if you have further query else please accept the suggestion.
Mar 02, 2011 | Maytag MAH6700A Neptune High Efficiency...
During a normal wash cycle, the error code FH occurs. The owners manual says inlet problem. All water pressure is good and inlet screens are clear. Drain function appears to work well. Repair guy came...
If the flow meter does not register 10 and 1/2 gallons of water in 8 minutes the FH code appears.
Could be a bad flow meter, sensor, wiring harness is loose or a bad CCU Central Control Unit.
At the RINSE cycle if water enters the machine you must time the water fill for 8 minutes or less.
If water does not enter the machine suspect the CCU as bad.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F11 error code
The F11 code means there is an electrical with the Maytag Epic washer. This could involve wiring, fuses or a number of other issues.
Press the "Pause" button twice to stop the current cycle. Press the "Drain" button to remove any excess water. Try to run the washer again. If the F11 code repeats, shut the washer off and contact a service agent
The FH error code may be mistaken for the F11 code. The FH code signals a water supply issue and has nothing to do with electrical problems. Check the LCD screen to ensure you read the proper code
Dec 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
Getting an FH error code during the cycle count down
The FH code indicates it is not detecting water fill at the flow meter. Since you say that the washer is filling okay, I would check the wiring between the flowmeter and the control board. A common cause of this problem on this machine is the wiring harness jiggling loose. Unplug and reseat the wiring harness and see if it clears up the problem. Also look for and clean out any corrosion build-up where the harness plugs in. Hope this helped and best wishes.
Aug 05, 2009 | Kenmore Elite 45986 Front Load Washer
Fault code
I have look over the codes for your model and dont see an FH code if you post your email here i will send you the service manual
Jan 26, 2008 | LG WM1814CW Front Load Washer
Washer trouble
fh means no water coming into washer. remove cold water line from back of washer and see if the screen in the valve is clogged. if so, remove screen and clean it, if not replaced water valve
Nov 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal De
