Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
A problem has been detected with this unit
Performed diag check found code the clutch is not mechanically engaging with the basket properly
    Problem Solver:
  • 4 Answers
Hi: Replace motor asm w/clutch part no. wh20x10024
 If you can put the washer to its side on the floor, check if the small white motor turns when you press start cicle.
Posted on Oct 11, 2007
Fisher and Paykel washer fault code 40. Is it possible to repair DIY. What to look for?
This is error code 40.
40. (00101000) Basket Dis-engage Fault
While carrying out a basket check, the Motor Control Module has found that the basket is
not engaged even though the pressure sensor indicates that the basket is empty. The
Motor Control Module continues to check for 2 minutes, after which time it displays this
fault. The first two areas to check are the clutch and the pressure tube. If these two
appear correct, then the fault could be in the pressure sensor in the Motor Control Module.
Primary Source: Mechanical.
Action: 1) Check that there are no clothes or other foreign objects preventing
the clutch from re-engaging. Excessive suds can stop the basket
rotating.
2) If the machine is empty of water, carry out a clutch disassembly
procedure and check the spline drive.
3) Next check that the pressure tube has not come off and that it is
not kinked.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
May 21, 2017 | Fisher and Paykel Washing Machines
My WL80t65C has had the RPS replaced, now won't spin the Bowl, does first stage of wash cycle then does not spin the Bowl. Times out. Code 40! Any ideas?
Fisher Paykel Top-Load Washer WL80t65C Error 40
Error Fault Condition
- Spin Basket Will Not Engage Or Disengage From Clutch.
Repair or Check - The spin basket has to be able to rise and fall with the water level. This is to engage and disengage from the clutch. Unplug the washer from power. Remove the spin basket. Remove any objects found between the spin basket and the tub. An object could be interfering with the spin basket clutch engagement. Replace any broken drive components.
Parts for Replacement - Drive Components.
Sep 20, 2016 | Washing Machines
Code error 40
40. (00101000) Phase 1 to 6 - Bowl Dis-engage Fault
While carrying out a Basket check, the Motor Controller module has found that the
basket is not engaged even though the pressure sensor indicates that the Tub is
empty. The Motor Controller module continues to check for 2 minutes, after which
time it displays this fault. The first two areas to check are the clutch and the
pressure tube. If these two appear correct, then the fault could be in the pressure
sensor in the Motor Controller module.
Action:
1) Check that there are no clothes or other foreign objects preventing the clutch
from re-engaging. Excessive suds can stop the basket rotating.
2) If the machine is empty of water, carry out a clutch disassembly procedure
3) Next check that the pressure tube has not come off and that it is not kinked.
Secondary Source: Motor Controller module.(Display Module Phase 1)
Action:
Replace Motor Controller module
Mar 31, 2012 | Fisher and Paykel Washing Machines
Code error 40
Action:
Action:
Mar 31, 2012 | Fisher and Paykel GWL11 Top Load Washer
Error code sd I tried canceling, starting over, rinse and spin, unplugging it oh and sparks when I plug it back in at the outlet Help
Suds Detection
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify:
Excessive detergent usage.
Basket cannot engage during drain step.
Mechanical friction on drive mechanism, not allowing basket to engage.It sounds like there is something causing a lot of friction and when you plug it in it has a load on the motor and you will get sparks.
Jun 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Suzuki rm 250
I wonder if the clutch "basket" broke off an "ear"?...I hate to say it,..but you might be in for a tear down and rebuild. Start with the parts you can access, clean/fix/replace with motor still in bike..eg; clutch plates/basket, "properly" fix the kickstarter spring/gear unit,...try to find thae cause of the metal filings,..check the clutch basket..etc. GL. [re-post with what's going on].
Apr 13, 2010 | Suzuki RM 250 Motorcycles
Clutch not egaging with basket for my profile harmony washer
If you are getting the message " The clutch is not mechanically engaging with the basket properly " the service manual says to check wiring connections, clutch motor or inverter board.
I rarely see a wiring issue. I'd check the clutch arm and clutch coupler too. They are nylon parts. I'll send you a couple pages from the service manual as soon as I get a chance to scan a few.
Nov 15, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Error codes
Her is the definition and a list of possiable causes.
Code P1740-Torque converter clutch did not lock up when the PCM sent the command. Enabling conditions: No engine or transmissions codes are present, vehicle speed was under 70 MPH, TPS was under 33% open. When the PCM commanded the torque converter to lock, no change was detected in engine speed. Blocking action: This code can block the following monitors: none.
Testing: Check torque converter solenoid for proper operation.
P1740 TCC O/D SOL PERFORMANCE (GAS)
Theory of Operation
The Torque Converter Clutch (TCC) Solenoid is used to engage the TCC which improves fuel economy.
When Monitored
The Torque Convertor Clutch (TCC) and Overdrive Clutch (OD) will be tested each time the PCM requests TCC engagement in 3rd gear and OD.
Set Condition
The DTC will set if the expected RPM drop is not achieved while attempting to engage TCC or OD. This indicates a malfunctioning torque convertor or overdrive clutch.
Possible Causes
* ENGINE DTCS PRESENT
* TRANSMISSION DTCS PRESENT
* TRANSMISSION TEMPERATURE TOO COLD
* OIL PAN CONTAINS EXCESSIVE DEBRIS
* 3-4 SHIFT SOLENOID
* SHAFT OR SEAL DAMAGE
* TCC SOLENOID
* TORQUE CONVERTER
Sep 25, 2008 | 2005 Dodge Ram 3500
GE Profile Harmony Clutch probs./Invertert PCB history
Your inverter board is operating 7 degrees over the max temp...
Clear this error be exiting the service mode and run set up ...
if it comes back you will need to replace inverter board....
let me know if you need more help...
Jul 30, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Won't Spin Without Assistance
It sounds to me like either there is an excessively heavy load in the washer and the unit simply isn't strong enough to get it going, or more likely the clutch mechanism/gearbox is malfunctioning. They use a clutch mechanism to allow the motor to run at a constant speed while the basket can start rotating slowly and pick up speed with time. If this clutch mechanism or gearbox isn't performing properly, the basket won't spin. It's not your motor or safety circuit since the basket will turn if given a little push.
Mar 10, 2008 | Washing Machines
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
385 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
