Question about Panasonic KX-TG5673B Phone
Fail base kx-tg 5673b
After the variation electric the base norecognized the handsets.the handset say no link to base the cloc´k blink in the base
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
  • 306 Answers
SOURCE: no link to base Panasonic KX-TG2357
are you running a wireless router? try unpluging router to test phone.
Posted on Jan 07, 2008
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
SOURCE: i have problems the no link to base with Panasonic
  • Press and hold the LOCATOR/INTERCOM button for the extension that is displaying "No Link To Base" on the Base until a beep sounds.
  • Press and hold the FLASH/CALL WAIT button on the Handset that is displaying "No Link To Base" until a beep is heard.
  • When registration is complete, a beep sounds from the handset.
  • Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
If this doesn't work or it keeps happening, replace the battery in the handset.
Posted on Jul 08, 2009
SOURCE: I have the kx-tg 4500
I had the same problem once, turned off the base unit from power cord and the phone line and all connected handset units, then turned it back on & it worked.
Posted on Oct 01, 2009
SOURCE: the (2) handsets are searching for the base
Problem solved; i applied the registration procedure as described in the manufacturer instruction manual page 34 Thanks for your help
Posted on Dec 05, 2009
0 characters
1 Points
Hi, suddenly I loss my connection of telephone KX-TG 5632to the base from the handy , I need the way to register it from the base, thanks for your cooperation
1 Handset: {MENU} i {0}{0} 2 Base unit: Press and hold {LOCATOR/ INTERCOM} until the CHARGE indicator flashes. L After the CHARGE indicator starts flashing, the rest of the procedure must be completed within 1 minute. 3 Handset: Press {OK}, then wait until the handset beeps.
Jun 12, 2011 | Panasonic KX-TG5632 Phone
Can I register a panasonic kx-tg55438 handset to a kx-tg5622 base
No, The kx-tg 5622 uses only the kx-tga560 (2 of them) for its cordless sets
Jan 07, 2010 | Panasonic KX-TG5622 Phone
Panasonic CORDLESS
1st check that the charger is plugged and energized. It should light up when dropping a hanset into the craddle.
2nd Check that the batteries are connected properly inside the handset and that they have the full voltage. Try 1st step again
Oct 14, 2009 | Panasonic KX-TG1033S Cordless Phone
I have the kx-tg 4500 4 line base unit phone. Line one flashes but does not ring or display caller. The other lines work fine. The handsets show no activity ie they don't even flash if a call comes in on...
Aug 05, 2009 | Panasonic KX-TG4500 Phone
Hi! This may cure your problem!
Re-registering the handset
If “No link to base. Move closer
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
handset to the base unit.
LMake sure the base unit is not being
LHave the handset and base unit near
each other when re-registering the
LKX-TG5422 and KX-TG5423 only:
Confirm the extension number of the
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
If you accidentally assign another
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
1} or {HANDSET
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
Hope this helps! Hal
Feb 27, 2009 | Panasonic KX-TG5422M Cordless Phone
KX-TG 5632
Hi John, It sounds as if your base has gone bad. If you have more than one handset on the system and they both are failing then its your base. You could possibly send your base in for repair or look for a cheap replacement base with handset. Wish I had a quick fix for you, but it sounds like a problem electronically and not a setting.
Jul 14, 2008 | Panasonic KX-TG5632 Phone
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Jun 22, 2008 | Panasonic KX-TG2313 Cordless Phone
Use 2 phones for one line??
take the 2nd handset to the working base unit and go to the menu, registration mode, and access handset registration. it must have the same password number as the first handset.Thank you. JER.
Feb 18, 2008 | Phones
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
Phones Logo
124 people viewed this question
Top Panasonic Phones Experts
Are you a Panasonic Phone Expert? Answer questions, earn points and help others
