Question about Philips 32RF52S 32" TV
Power on but shuts off
I have a problem with my 32rf52s327, when i turn on the power, it want to turn on, but shuts down, the red light blinks twice please help.
The amount of blinks are an error code.  Cant find my info as I type this but it represents some trouble.
Posted on Oct 25, 2007
Its broken
Posted on Oct 02, 2007
My sony kdf e50 12u wont turn on red light blinks twice
Your TV is giving you a code, something is faulty in the system, usually 2 blinks of the red light indicates, Load on power line is shorted. I also would check the bulb also to make sure it doesn't need replacing.
Jun 22, 2012 | Sony Televison & Video
I need a code and instruction to program my remote control with a magnavox tv
  • The Magnavox codes are 32114 and 11434. Should those codes not work then follow these steps to do a code search that will find the code inside the remote.
  1. Turn on your TV.
  2. Press and hold down the SET UP key until the red light blinks twice.
  3. Press Programme - three times. The red light will blink twice.
  4. Alternate between Programme- and Power until your TV turns off.
  5. You may have to press these keys many times, so please be patient.
  6. When your TV turns off, press the SET UP key to store the code. The red light will blink twice. Your TOTAL CONTROL is ready to run your TV.
Regards, Tony
May 18, 2011 | One For All URC4110 Remote Control
Power light blinks red
Hello, If you can turn it back on with the s momentary key or power button:
When it shuts off, do you need to push the power button once or twice to get it back on? Also, does anything else about the picture or sound change as it warms up?
If once, then the controller is shutting the TV down either as a result of a (thermally induced) fault in the controller or it sensing some other problem. Monitoring the voltage on the relay coil (assuming these is one) could help determine what is happening. The controller thinks it is in charge.
If twice, then the power supply is shutting down as the controller still thinks it is on and you are resetting it. A couple of possibilities here would be low voltage or high voltage regulation error (excessive high voltage is sensed and causes shutdown to prevent dangerous X-ray emission). A partially dried up main filter capacitor could also cause a shutdown but there might be other symptoms like hum bars in the picture just before this happened. Clipping a good capacitor across the suspect (with power off!) would confirm or eliminate this possibility.
If it uses a pull-knob (or other hard on/off switch), then this may be like pulling the plug and would reset any abnormal condition.
May 20, 2010 | Philips 50PFP5332D 50 in. Plasma...
Hello, We have the Panasonic project TV (PT-50LC14). We purchased a new bulb this past July. We're now experiencing problems with the TV. After turning it on for less than 5 minutes, the TV shuts off. ...
Hello well this kind of problem all the time is because you have a fan problem and you could have dirt inside of your tv and sounds also like a ballast problem i have this issue also and I got connected on the live chat that a web say has that they call discount-merchant they sell parts and lamps for TV they could help you they help me twice.
Regards
Jan 01, 2010 | Panasonic PT-50LC14 50" Rear Projection...
I try to turn on the tv and the green light just blinks, nothing happens. After a few minutes it shuts off and the red light blinks two times and pauses. The red light blinks until I disconect from the...
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Dec 06, 2009 | Panasonic PT-56LCZ70 56" HDTV
Red Light Flashes twice KDF-E50A10
Are you putting the lamp cover back in place before trying to turn the set on? The 2 blink error is a temperature error you might want to check the thermal sensor, is your lamp door warped?
Oct 30, 2009 | Sony KDF-50E2000 50" HDTV
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
Philips 32RF52S 32" TV Logo
128 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
