Question about Denon AVR-1707 Receiver
No sound from my Denon AVR-1707
I have composite video cables running to a front projector. I have digital coaxial audio running to my Dennon receiver. My DVD player is a SD4990su. I have no sound. I did the automatic sound set up with minimal problems, but I can't figure out what I am missing to get sound rom the DVD player. Help!! Thanks
  • Anonymous Mar 23, 2014
    Mine is an AVR 3802 and connected to it is a long co axial cable that runs from my bluray player. The bluray player sits adjacent to the projector but the receiver is about 15ft away. Hence the long cable. The problem I face is the audio ( on auto scan mode) getting cut during certain peaks (only)and the amp searches again for the signal that subsequently returns in about 20 secs. This happens atleast a couple of times during a full movie run. Thanks.
  • 93 Answers
I think that's something in SOUND SETUP menu incorrect. Try to redo it again.
Posted on Oct 03, 2007
SOURCE:
Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
How do I set my receiver to read TV/CBL Dolby Digital. It is a AVR 789
The Dolby digital signal is outputted only through the Optical or Coaxial socket of the CBL box. you will have to get an optic fiber or coaxial cable depending which cable box you have and connect it to the digital input of the Denon receiver. The Denon's digital input are already assigned at the back. Eg: Optic input might be labeled CD so if you are connecting the CBL box to the optic input remember to select CD on the Denon to hear the cable sound, same goes with the coaxial input.
Aug 27, 2011 | Denon AVR-788
I have a Denon AVR-1707 with a center, 2 front speakers, and surround sound back speakers. When set to FM radio, all speakers work. When set to TV, only one side speaker works. Any ideas? It worked fine...
Follow the sound back to its source. FM is internal so it can't possibly have a cabling issue.
I imagine your TV sound ultimately originates from a cable box which has a nice juicy digital output that the Denon could use. Why route audio through a TV, like the manuals tell you, when you can get it straight to the best audio device without a detour to a TV and its dubious audio electronics?
Apr 17, 2011 | Denon AVR-1707 Receiver
I have an avr 3200 can it use 2 coaxial inputs and how good is the sound quality compared to newer avrs
Denon being one of the best names in the biz and this being an upper-crust modfel, I'd say anyone without a 'golden-ear' would be hard pressed to t\distinguish its sound from any other amplifier in existence.
The Denon site doesn't list and AVR-3200, but the AVR-3300 has 1 coaxial digital audio and 3 optical digital audio inputs.
If you're looking to run multiple coaxial devices and there aren't enough inputs this is what I do...
Helpful hint: Coaxial digital audio cables can be joined using an RCA cable splitter so they can share a given input or distribute a given output to multiple places. You just have to remember to have only the DESIRED units turned on when sharing or there will be digital confusion on the buss and it will result in silence or horrendous noise.
Jan 15, 2011 | Denon AVR-3200 Receiver
Hi, i have the Denon AVR-2802 reciver. My issue is when i plug my xbox into the dvd compontent inputs, i cant get any audio or video. I was working a few days ago, i had to disconnect the amp, when i...
Component inputs are for video only, and when connected through a receiver then the television also must have a video input coming to it from the video out from the receiver. If you want audio that will be a separate connection from the xbox to the receiver either by digital coaxial cable or optical cable, or composite.
Dec 15, 2009 | Denon AVR-2802
Where do i plug in the yellow, red and white cables on the Denon avr 1707 for connection to wii
the yellow goes to the tv then you can have your audio run through the receiver for sound or you can plug in the tv audio in.
Oct 24, 2009 | Denon AVR-1707 Receiver
Hi with my denon avr 1908 can i run video through HDMI cable and sound trough Coaxial cable so i can get 5.1 surround from my sky HD box
you can get 5.1 using HDMI connection.
other wise in the set up you can configure the denon to not use the hdmi audio and configure that input to use coaxial or optical all digital inputs allow for 5.1 once all connections are made on the front of the unit find the input mode button and select auto
Jun 30, 2009 | Denon AVR-1907 Receiver
Denon AVR 1803 Receiver lost audio
Make sure your receiver is set to either "auto-select" or "digital" rather than "analog" (button on front display).
May 25, 2008 | Denon AVR-1803 Receiver
Denon AVR-1707 Receiver Logo
477 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
