Insignia IS-PDVD10 Portable DVD Player
Rolling White Screen
posted by qzsrqh on Oct 01, 2007
Bright WHite Screen, occasional vertical color bars. Screen won't stop rolling. Is this worth fixing / very expensive?
Thanks
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 17, 2008
Helpful (85)
LabRat3
Rank:Wiz Wiz
Rating: 83%, 46 votes
Sounds like your inverter board has failed.
Yes, it is an expensive fix. You can try asking Best Buy if they can repair the unit if it is still under warranty, or what it will cost to have it repaired by the Insignia people.
If the player still works, you can try using it as a set-top unit and connect it to another monitor through the A/V outs.
Rating Locked! (?) qzsrqh has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Rolling White Screen:
I don't want to Accept this solution
Can you Help with these DVD Players problems?
Insignia Portable DVD Player does not play DVDs - says no...
Everything works fine with the dvd player except the...
I need some replacement parts for my DVD player, i.e. the...
Sir I have purchased DVD Player model IS-PDVD10 and...
i have an insignia ns-pdvd10. after about eight hours we...
Loading problems.
Repair Service
Find DVD Player Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
