Question about ASUS P5S800-VM Motherboard
No any display in the monitor, no beep of the RAM while CPU fan is running
I have been using a home assembled PC includes processor Pentium-4, 2.66 Ghz, using ASUS P5S800-VM motherboard with SIS 964 chipset. One day when I started my PC, it stopped responding. Current to the motherboard is on. CPU and SMPS fan are running properly but no display in the monitor (monitor works with other PC). I have changed the DDR RAM and also cleared RTC RAM. Still there is no respond. PLEASE HELP ME TO RECOVER THE PC
  • tbreed Dec 16, 2007
    its happend before when i tryed installing a gig of ram the computer powered up and all the fans worked but the monitor was unresponsive. and happend again today when i tryed upgrading with a video and sound card and some fans. i tryed uplugging the fans and cards and everything but the pc remaind unresponsive but everything seemed to be working
  • Anonymous Mar 17, 2014
    P5S800-VM SiS 661FX/964 LG
  • 71 Answers
Check your power supply. It sounds like you have a bad power supply. Even though the computer powers up, it does not mean that it's good. I have had this problem before, and almost 9 out of 10 times the power supply had gone bad. Just try a different one and see. hope this helps you.
Posted on Oct 01, 2007
SOURCE:
After i change the processor dual core 1.80ghz on the IBM thinkcentre M 55e 9632 series the monitor only showing, cpu=1processors detected,cores per processors=2 intel pentium dual cpu 2160 1.80ghz 1527...
HI,
I am sharing some general info:-
If you are change processor no problem, some point see you like after change processor any beep sound, processor more hitting.
Second check it *********** board power come or not, your display cheap more hitting or not. Check RAM proper connect, your all cable proper connection. If all things ok then may be your PC not supported processor.
Thanks..
Oct 14, 2013 | Lenovo ThinkCentre M55e 9632 PC Desktop
My display unit of my ACER PC show no signal,but it is on. what can be the problem?
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Jun 02, 2011 | Acer AL1716 17" LCD Monitor
Hi! My Hp Pavillion a1710n desktop emits a series of never ending beeps every time I turn it on, and nothing appears on the monitor. I checked and the monitor is plugged in. I dont know what's going on.
The problem with RAM or DISplay card(It can be Moisture problem) or Processor Fan is not working properly. Open the CPU case, locate RAM, remove the ram by opening the both side clips. and put the RAM back as it is. If you have Graphics card on your CPU then remove the Graphics Card also and put it back as it is. Start the PC with opened case to check Processor Fan is Rotating or not. If Fan is not working properly then you have to replace the Processor FAN. Fan ok but same problem persists. you have to replace RAM with new one. as well as Graphics (Display) card.
Jan 19, 2011 | HP Pavilion A1710N Desktop PC
How will you know if the processor is still working?
Finding Out the CPU condition whether its working or not
  • 1
    Turn on your PC and listen for a beep. Your computer runs a diagnostic upon startup called "post." Post checks for the basic requirements for your system. This includes RAM, processor and video functions. If those three basic elements are working properly, you will hear one beep from your computer's speaker and you can be assured your processor still works.
  • 2
    If you hear multiple beeps, count the number of beeps you hear as this will help you determine if your processor is functioning properly. If you are running Phoenix BIOS, make sure you count and write down the beep sequence.
  • 3
    Consult your motherboard's BIOS instruction manual; there will be a section on the "post" startup. Five beeps means a processor error for most standard AMI BIOS systems. The number of beeps you here will tell you the problem your computer is experiencing that is preventing it from booting up. Once you know how many beeps to look for, you can safely determine if your CPU is still functioning properly.
  • Jan 19, 2011 | Intel Pentium 4 2.40GHz 512/400/1.5V...
    Heating problem?
    You could get an Intel Water Cooling kit
    Jul 11, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
    Fan running, HDD light solid, no display
    I assume there are no post codes (beeps)?
    Pull everything including the video card, leave only the RAM and CPU installed.
    Try powering it on, You should hear a long beep, then some short ones to tell you the video card wasn't detected.
    If you still don't get any post beeps, try resetting the BIOS, and re-seat your RAM.
    If it still doesn't post it could be a system board mounting issue, bad system board, bad RAM, bad CPU, or bad Power Supply
    Jun 24, 2009 | E-Machines T2240 PC Desktop
    No display on computer
    First thing is do you have a beep when the system boots? Sounds like you may have a BIOS issue I would start there........your RAM and processor are more than likely NOT the problem
    Apr 15, 2009 | HP Pavillion a818n Desktop PC (Refurb)...
    Pc is not booting and no display in monitor
    First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
    Sep 11, 2008 | ASUS (P4BGV-MX) Motherboard
    No Beep No Display
    motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
    Jul 03, 2008 | Intel Motherboard
    My 4-pin cpu fan is not running
    check the power connection for your mother board and fan
    Mar 09, 2008 | Computers & Internet
    ASUS P5S800-VM Motherboard Logo
    295 people viewed this question
    Top ASUS Computers & Internet Experts
    Ekse
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
