We have a 4 month old 4247 that is printing data from an AS/400 via an ethernet network & T1 line. It will be printing fine and then, midpage, it will start printing out mostly p's, q's and r's seperated by commas. Sometimes it will work for several weeks before messing up. Sometimes only hours. The AS/400 experts at HQ says that it is the printer... any ideas?
Comments:
Mar 06, 2008
- It ended up being a defective printer cable. Have a good one.
-   I am actually using a 4342, however it looks exactly the same running on an AS/400 system. The printer stops on an 056 Machine error shortly after its restarted due to locking up. After flashing the error it goes into a "Not Ready" state and connot come out of it, the "Ready" button does not respond, nor does the "Online" button until its hardbooted then in repeats this cycle.-   dt0702
I have an IBM 4247-A00 printer with no documentation. How do I change the forms width to...
(More)
I have an IBM 4247-A00 printer with no documentation. How do I change the forms width to 132-characters? Thank You.
I have an IBM4247-A00. It has an Axis network print server (540+/542+) attached for tcpip n/w...
(More)
I have an IBM4247-A00. It has an Axis network print server (540+/542+) attached for tcpip n/w connectivity. In the set up of this server it is currently set up as laserprinter. I believe that is the default. What should it be? Thanks
After an IPL on the Iseries, our 4247 printer will not connect back to the ip network with out power...
(More)
After an IPL on the Iseries, our 4247 printer will not connect back to the ip network with out power down and back on. Is there is a setting that could fix this?
