LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
