Question about Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher stopping mid program
I am experiencing problems with my Ikea whirlpool dishwasher. When I start it it runs like normal for about 15 minutes, then it just stops (the power lamp is still lighted). This happends on all programs. When I open it there is hot water in the machine. The soap container has emptied also. I suspect that it is a problem with draining the water, because there are no problems when filling the machine with water. Is it correct that water is supposed to be drained about 15 mins. into a program? I have checked and cleaned the filters and there are no visible objects blocking the flow of water. Could it be a problem with the pump that is supposed to drain the water? Would that scenario be causing similar symptoms?
    Novelist:
  • 148 Answers
Sometimes machines stop to heat the water. does your machine ever start again?
if it does not start on its own, it could be a time issue, or a heater element issue. if it calls for heat and it never heats, it will never run.
if it ever drains, then the issue is not the pump. its a logic board.
good luck
mark
Posted on Dec 28, 2007
SOURCE:
Whirlpool quiet wash plus dishwasher
Sounds like the timer module is going bad. Might be getting moisture on contacts. That would explain why it works one time and not the next.Just trying to help!
Aug 14, 2013 | Dishwashers
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after...
Anyone got an answer to this, as I have exactly the same fault.
Dishwasher appears to switch on OK, then after a short time (20 secs?) the pump noise stops and the green light flashes - it seems to e a sequence of 7 flashes, then stop... 7 flashed then stop.
The sequence could indicate a fault detected?
Anyone know anything about these units from IKEA, made by Whirlpool?
Thanks!
S
Feb 12, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Ikea Whirlpool integrated dishwasher door front
how do i take door off to fix handle back on dishwasher
Jan 03, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
IKEA Whirlpool DWF 403 W Dishwasher buzzing
When it's buzzing, you have to let it buzz until it stops. Then you pressed stop then start. Et voilà!
"S" means salt, but you can use any salt you want.
Jun 11, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
DU1100 Stops mid cycle.
main control cpu unit failing
needs to be replaced
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool GU2400XTP Built-in Dishwasher Logo
338 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
