Question about Brother MFC-3240C All-In-One InkJet Printer
Can't scan a page and send
Very Simple machine says there is a problem
  • 22 Answers
What does the display say? Power the machine off for one minute. Put your finger on the stop key first, plug the machine back up and hold the stop key until the time and date return to the display
Posted on Oct 02, 2007
When we start to send a fax the machine shows "memory" in the window and the fax will not go through. If we continue to try, after 3-4 times the fax will finally go through. Any idea what we can do to stop...
If this is a newer style machine...most units scan the pages into memory before they send it. What are you trying to send???? is it a complex color brochure..????
Try sending a simple page of type and see if the machine does the same thing. This may be a limitation of the memory capacity of your machine.
Apr 07, 2010 | Office Equipment & Supplies
I need to know how to send a fax from a brother MFC-295cn all-in-one printer
Hello Frank,
Sending a fax is fairly simple.
1. Make sure you have a telephone line connecting to the LINE jack on the side of the MFC-295CN
2. Check if you have a dial tone by pressing the "hook" button on the machine while the line is free.
3. Place a page face down on the flatbed scanner or in the document feeder on the top of the machine.
*Note: If you are using the document feeder, once the page is placed in, you should see "enter fax #" on the LCD
4. Enter the fax number the same way you would dial a regular phone number.
5. Press "Start"
*Note: If you are using the flatbed option, after the sheet is scanned, you will be asked if you want to scan a second page. For additionnal pages, press 1, to end scanning and start faxing, press 2
6. If the fax goes through properly you will see "completed" on the LCD
Mar 25, 2010 | Office Equipment & Supplies
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
the key will glow green.
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
The machine starts scanning the
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
Dial the fax number.
If you press Black Start, the
machine starts scanning the first
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Sending multiple pages in one email attachment after scanning
well go to scanning setting and change it, you change the setting to be sent one by one, if its connected to network, browse the ip address and go to scan and change the setting, if to usb cable go to the driver setting and change it, and i think from the machine setting itself can let you, so its just setting.
Mar 21, 2009 | Brother MFC-7420 Laser Printer
How to scan using a sharp mx3501n?
as long as your machine has been configured within the network settings. press the image send key then addres book then enter your email or select the folder or email addres to send it to.
Dec 02, 2008 | Office Equipment & Supplies
Storing Outbound Faxes not sending.
if you print a tx journal does it have an error on those you tried to send
Mar 19, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Does not scan pages until it makes connection
yes, the solution is that you are direct sending the faxes instead of scanning into memory which will start and complete the scan of all the pages as it begins dialing and transmitting. there should be a key on the control panel for memory or memory transmission, select it and your done.
mikey
Mar 14, 2008 | Brother IntelliFAX 4100 Laser Fax
Memory Sending
~When sending one page, does the display indicate usage of any memory ? If it does then it is merely a feeder problem. If you open up the front flap (the whole panel holding all the number keys and display it hinges forward) you will see to the rear of the machine two rubber rollers - the rubber 'goes off' after a bit - it either dries out/ perishes or gets dirty. You can try cleaning these with a slightly damp rag (avoid paper towels/ fluffy cloths). However, if they have gone past their use by date you may have to consider replacing your machine (unless a proficient engineer can replace them for less than the cost of a new machine). Whilst the front flap is open, below the lower of the two rubber rollers is a glazed screen which houses the scanner. Run you finger across the glazed area and see just how much dirt is being scanned across each of your pages being sent - you might be surprised!
In the meantime, this is not an unusual situation - but do you really have to send 80 pages of fax (5 - 20 I can understand)? The risk of missing one page (and it being a crucial one is too great). However, my L350 will not pickup following pages and is much happier sending single pages only. The only solution, I am afraid, is for you to stand over the fax and feed one page in after another, just as the previous one leaves the input tray. You can keep an eye on how many pages have actually scanned and if it matches up with how many you have fed through by keeping an eye on the page count on the machine's display.
Can't offer a better solution i am afraid. hope this helps tho.
Feb 20, 2008 | Canon FAX-L350 Plain Paper Laser
I want to scan then send instead of scanning whilst sending
There are 2 methods of sending 1. Through memory, in which the machine scans the document then sends when all pages have been scanned. 2. In real time, in which the document is placed in the ready mode and the line monitor or handset is used to dial the number. In this case the document is not scanned until a response is heard from the other machine.
However, in the case of the memory being full, either of documents in the queue or if there are documents waiting to be printed (because of no toner or no paper) then the machine will not allow sending from memory.
Feb 07, 2008 | Canon FAX-L200 Plain Paper Laser
Brother MFC-3240C All-In-One InkJet Printer Logo
26 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
