Question about LG (GSA-5169D) DVD RW Dual Layer Burner
Burning CDs It keep saying that I need to insert blank cd. They are new cds. I was told to try Maell brand cds but that didn't help. I ininstalled the program and then reinstalled,but it didn't fix the problem.
  • Rebatom Nov 02, 2008
    Will play audio cds and play dvds but doesn't see blank media
    Problem Solver:
  • 17 Answers
Do you experience this issue only with CD's or does it also occur with blank DVD's?
Posted on Oct 02, 2007
SOURCE:
My Iomega CDRW64001 keeps ejecting my blank CDs. The external LED blinks for several minutes and then ejects the CD with or without a burn program open. It plays recorded CDs and I'm able to install...
Your best solution (since your USB devices and your network-adapter are not working) is to remove the disk-drive from the old computer, and temporarily connect it as a "slave" disk-drive in the new computer, and then copy all your files from "old" to "new".
Or, try a different brand of "blank" CD-R disks -- the "firmware" (software inside the CD-writer) may not be recognizing "newly-manufactured" media). Unless you can update the firmware (by downloading the latest firmware on another computer, and burning a CD-R disk, and then taking that disk to your computer), it's easiest to "move" the disk-drive to the new computer.
Jul 16, 2010 | Iomega (32885) CD-RW Burner
My cd rom won't detect blank cds
try re-installing your burning software ( nero-Roxio et,c )
Does it play a standard Music/Audio CD.
if not un-install and re-install the drive.
Are the cables to the drive connected correctly ?
Does the drive support CD+ And CD- media ?
Are the cds definately Blank, any small amount of data written to them, after failed burn attempts will not show the disk as being empty.
Mike @ Compurepair.
Jun 13, 2009 | Dell Computers & Internet
ROXIO CREATOR LE DELL EDITION CAME WITH MY COMPUTER AND WORKED PERFECTLY UNTIL SEVERAL MONTHS AGO. I CAN BURN DVD'S, AND I CAN ADD PICTURES TO A DISC WITH PICTURES IF IT SAYS APPENDABLE. WHEN I PUT IN A...
there are alot of kind of cd brand, like, maxwell. princo, ech.... use the common cds or dvd brand. may this cause of cd only. not good quality..otherwise chech your cd room drive. maybe the lins can recognise try to change another cd or dvd room for testing only.. befor you buy or changing totally..
thank you
May 29, 2009 | Roxio Easy Media Creator 8 Deluxe Suite...
I have just brought a new pack of blank CD's, i am
Its a common problem with CDs. Check that your CD drive can PLAY CDs. If so either the CD drives optical head is dirty or your CD pack are low quality. CDs damage real easy. Try putting another CD, another brand or you must use CD doctor-something like that. Did that help
Mar 10, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Error message E-8302
It sounds like you might have problems with your CDs. If you are burning CDs on your computer to play in the CDJ, you need to remember that it will only play audio (wav), or MP3 files. Also, blank data CDs are cheaper that buying audio / music CDs. When you burn your CDs to play back on the CDJ, you have to be sure to burn them as wav or mp3. AAC, MP4, OGG and the other formats will not work in the player. When you burn the CD, ALWAYS burn at a slower speed than what the computer will automatically burn at. You will have to manually set the speed yourself.
Personally- when i burn my tracks CDs for my CD book, I use trusted name brand blank data CDs such as Memorex, Sony, TDK, Fuji, Imation. I burn them as AUDIO ONLY. To avoid any reading mistakes that could happen with any given CD player, i NEVER burn track CDs as mp3. When i burn the CD, i set the writing speed to 24x, 30x, or 32x. I recommend that you DO NOT burn your CDs at any speed faster than 32x. From my experience, that is the fastest and safest burning speed. If you do these things, and you still have problems with the E-83 02 code, then it will only have to be the kind of CDs your using to burn, or your CD burner in your computer. Notice how i didn't mention Maxell CDs up top. 3 months ago, i bought 2 spindles of Maxell data blanks on sale for $9.99 each. I was happy i got them that cheap, but the CDs themselves were no good. Recording everything the way i do, they had popping noises and scratching sounds through-out the disc. I gave the spindles to my neighbor. He was happy to get blank CDs free. I WILL NOT say that Maxell makes a bad product: I still record on cassettes and Maxells are one of my top 3 choices for blank chrome tapes. But the discs i bought were just a bad batch. Maxell is still a trusted name for blank tapes with us older DJs that started out with recording on tapes before the CD format became way cheaper and affordable.
Try burning your discs as audio only, and burn them at 24x, 30x, or 32x ONLY. Buy better brand name data CDs, and you should have no problems. If you use my method as an example, and you still have problems, then you need to get a new CD burner for your computer. They are always cheaper at Staples or Office Depot. Hope **** works out for you : D
Nov 08, 2008 | Pioneer CDJ-800 Turntable
Error message
Sep 17, 2008 | Pioneer CDJ-800 Turntable
My cd is well ....i have no idea
Sounds like a tough problem to have because half of the CD drive is working fine (the reading part) but half isn't (the writing/burning part).
Here are a few suggestions:
1) try a different CD writing program, if the Wizard says the CD-Rs are full, try a version of Nero or a freeware burning program.
2) if, when you load the blank CD, Windows says that it's unable to burn it, it might not be a CD that your burner can recognize. If you are using different or new CDs, try another one or borrow someone else's blank CD. I've had it happen where a set of CDs that I bought were bad and couldn't be used. Also, some cheap CDs don't work on some CD burners.
3) It might be a bad CD drive. If it's an older computer, you might have to get a new CD drive. Before doing this, I'd try reinstalling the software and drivers for your CD burner and try both the suggestions from above. Good luck
Sep 09, 2008 | Compaq Computers & Internet
Cdj 800 error 8301
Error Code
E-72 01
E-83 01
E-83 02
E-83 03
E-91 01
Description
Player unable to read TOC data.
Disc is rotating, but rotation cannot be ascertained.
Player unable to play back currently inserted disc.
Mechanical operation has failed to complete within
specified time interval.
Possible cause and recommended action
Disc is cracked.
= Recommended action: replace disc.
Disc is soiled or dirty.
= Recommended action: clean disc.
If other discs play normally, the problem is with the disc itself.
Dust or some other form of foreign particles have found their
way into disc insertion slot.
= Recommended action: remove dust or other foreign particles.
Error Type
TOC READ ERROR
PLAYER ERROR
MECHANICAL TIME OUT
Jun 11, 2008 | Pioneer CDJ-800 Turntable
Lite-on DVD R/W combo LH-20A1L BLO5 Blank discs not recognized
Have you checked device manager to see if you have a yellow checkmark on your DVD./CD drives? if ok, sounds to me like the maker of the LH-20A1l BLO5 either needs to fix your problem or replace it. The Nero 7 should enable it to work correctly.
Feb 14, 2008 | Computers & Internet
LG (GSA-5169D) DVD RW Dual Layer Burner Logo
118 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
