Question about Blodgett Model Mark V Single Electric Oven
My oven doesn't come up to temperature and the blower fan stays on when the doors are opened.
  • Anonymous Apr 11, 2008
    oven dosn`t come up to tempture
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 26 Answers
Switch is in COOL DOWN position. Set to COOK.
Posted on Sep 02, 2009
SOURCE:
What are the possible sources of the following problem? Our convection oven works fine when it's turned on in the morning. However, when you open the doors for too long, the fan needs a manual push
The oven is designed to turn off the fan if the door is left open too long. I think it is a protection to avoid injury to the user due to heat circulation. It might be best to turn down the heat setting when opening the oven for long periods whilst the cooking is on. If you want the manual it can be downloaded from this site. see page 23.
http://www.blodgett.com/wp-content/uploads/Zephaire-100-G-200-G-ES-man-english.pdf
Aug 26, 2014 | Blodgett ZEPHAIRE G SGL Gas Single Oven
Blodgett oven mark v 111 can cool down but not cooking
door switch need to be checked or repalce. you can put 2 wires connect together and turn on see motor is running, if it run that mean switch is bac...good luck.
Jun 05, 2014 | Blodgett Model Mark V Single Electric Oven
My company has Blodgett Gas Convection ovens, model # DFG100. Where is the serial number located on these ovens
The serial number is under the left side door behind the cover. Open the doors take out the two phillips head screws which go into the top of the lower cover, one on each end just inside the door hinge, the lower cover will remove to the front.
Jun 28, 2011 | Blodgett DFG-100 Gas Single Oven
Ge oven turns off by itself, and sometimes gives
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
I am looking for the schematics for a Blodgett Mark V I.Q. Single Phase
http://www.blodgett.com/index.htm
start with this web site. It has lots of manuals. Surf this site. I would need more info on your model to go any farther for you.
Hope this gets it for you.
Oct 23, 2009 | Blodgett MARK V Oven
Blodgett
Go here find what you seek. Great Co.BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Feb 25, 2009 | Blodgett Model Mark V Single Electric Oven
Blodgett oven
Go here to find what you seek. They are a Great Co. ready to help
BLODGETT
Nov 11, 2008 | Blodgett Model Mark V Single Electric Oven
CTB temperature adjustment knob shaft
The blodgett part number you are looking for is 18234 Potentiometer remote (infinite control) I dont know if you are able to buy directly from blodgett here is the number for blodgett 1-800-331-5842 the blodgett web address is blodgett.com if you are not able to order from blodgett you might try another company generalparts the number for general parts is 1-816-421-5400 kansas city location. the web address for general parts is generalparts.com
May 13, 2008 | Blodgett CTB BASE Electric Single Oven
Mark V Blodgett oven manual
Go here and find what you seek.They are a great Co.
BLODGETT
Feb 28, 2008 | Blodgett Model Mark V Single Electric Oven
GE self cleaning radiant oven - model JB578GP
I went out to my circuit breakers and turned the circuit off, let the oven cool, and powered it back up after about 2 hours. Fine now.
Feb 17, 2008 | GE Profile JT912 Electric Single Oven
Blodgett Model Mark V Single Electric Oven Logo
232 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Steve Allison
Steve Allison
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
