How to downloas drivers for faxphone b95
SOURCE: Check printer ##331 CANON FAXPHONE B95
HI your problem in fixing unit change it and your problem will be solved
SOURCE: Setting up a faxphone B95
User guide is available for download here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=338&modelid=10586
please rate solution
SOURCE: have a canon b95 faxphone machine.
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
Testimonial: "Fantastic response. Clear and very helpful. Fixed the issue imediately. Thanks"
SOURCE: Canon Faxphone 15 user's manual
Plug the power cord it into the wall socket. Plug in the phone wire. There is an On/Off switch on the back. You will need some thermo-paper that comes in a roll, a roll like toilet paper, thinner than regular paper. The instruction of how to load it is on the top paper cover. Good luck
SOURCE: can not find a cartridge for the faxphone b95 at
I get mine from Cartridge World but Walmart usually has them I think
