Sharp AF-S120FX Air Conditioner
Problem for Sharp AF-S120FX Air Conditioner
Room Air condotioner Sharp AF-S120FX-A noise from middle of fan
By burlam18 on Apr 29, 2009
noise goes from front of conditioner, from middle of the fan right in that moment its starts to turn.
If it bearing - is it possible to lubricate it somehow?
Thanks.
Comments:
Apr 30, 2009
- I did it. I lubricated the shaft from both sides, but noise continues. Probably it is inside of the motor .
Best Solution
posted on Apr 29, 2009
Helpful)
Healeyman
Rank: Wiz
Rating: 82%, 224 votes
You can get a zoom spout oiler at your hardware store. Slide the ac out of its housing until you can see the fan motor clearly. Use a flashlight to see the shaft. Put oil right where the shaft goes into the motor, both places if you can see them. While there, check the ac for sludge or anything else you can **** up with a shop vac.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 04, 2009
Not Rated)
sasoo
Rank: Apprentice
Rating: 0%, 0 votes
sharp inverter air condition keeps switching off after every 5-10mins!!!!!!!!!! and its hot!! its so hot! i just want it to be on 20C all day long, all night long... is there anyway of doing this??? back of remote it says, CRMC-A357JBEO, then RO3 (AAA) 2PCS. what should the timing and circle pictures be on? which fan should it be on? which buttons am i pressing wrong?? Please someone help me, im melting!
Was this helpful?
Yes
No
Popular Solutions for Sharp AF-S120FX Air
Questions and Unsolved Problems for Sharp AF-S120FX Air
Do you recommend Sharp AF-S120FX Air Conditioner?
Answer
Answer
I have a sharp remote controller CRMC - A310JBEO I am looking to get another remote as I have 2 AC... (More)
Answer
My mom start the air conditioner (Sharp AF-S120FX Brand) with a cover at the back and after 5 mins.... (More)
Answer
the EI code came on and I cleaned the air filter and now the unit runs for about 5 mins then shuts... (More)
Answer
Fan not running, sounds as if everything else wants to work, but no fan to put out cool air.:( Help.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AF-S120FX Air...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
