Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi vs-50703 I have been told that my tv has a bad power supply and I will have to replace or rebuild the board. What should be the cost of replacing the power supply board new vs. a rebuild kit if I hire out? What is exactly in the rebuild kit and where could I order one if I decide to do myself?
    Genius:
  • 1,694 Answers
NO POWER===Check all fuse devices on PS PCB. Shorted convergence IC's will cause that== change IC's.See what you have-let me know what you find.
Posted on Oct 04, 2007
Timer light constantly flashing and tv does not turn on
You have V-26 chassis type of the TV. Mitsubishi had recall on these models but it's already expired. Repair out of the pocket will cost you not less than $700, chassis have to be sent to Mitsubishi for complete rebuild procedure (involves 5 PCB boards and many, many components to be replaced). In your case reboot sequence does not comes to completion because of bad capacitors in DMD and/or power supply boards.
I would suggest cut your losses and invest in new TV.
Mar 10, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Cost to replace signal board
The signal board is not likely to be the cause of this. I'll research this a bit and update this with some sugestions. Can you solder?
Dan
Feb 11, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi vs-50703 65 in. Rear Projection... Problem: tv wont turn on
that model is famous for the CRTs leaking coolant onto the main board near the vertical output Ic and causing the set not to power up. Check the fuses on the main board and also look for evidence of leaking fluid which often appears as a stcky residue it should appear shiny with a bright flashlight.
Apr 22, 2008 | Televison & Video
Mitsubishi VS-50703 blurry after move
A halo effect usually means the coolant in the CRTs need replacing in the effected color usually blue goes first followed by green. red seems to be less prone for some reason.
Jan 14, 2008 | Mitsubishi VS-50703 50" Rear Projection...
Green "halo" around the bright white images
I have a Samsung HCM5535W rear projection TV that had pretty much the exact same problem-- a green halo around bright white images. I researched it on the net, and determined the most likely problem was with the convergence STK-ICs, or the convergence board. I bought a replacement board with the STK ICs and installed it, but no luck, the problem persisted. I decided to mess with the manual focus adjustment on the green crt (i was seeing a green halo), and that fixed it. As it turns out, no replacement parts were necessary to fix the problem in the first place. Hope this helps somebody out there.
Nov 14, 2007 | Mitsubishi VS-50703 50" Rear Projection...
Have sound but no picture
solder alot of connections on power supply board and in deflection/ High voltage section on deflection board.
Jul 07, 2007 | Mitsubishi VS-4544 45" TV
Mitsubishi VS-50703
To Fix TV: Press Menu then 1-7-3-0.
Make sure Initial is highlighted in yellow and press Enter.
To get additional input channels:
Press Menu/SetUp/AV Connection/Locked to Input 1: Should be on NO.
1(800)332-2119 Mitsubishi Customer Support
Apr 16, 2007 | Mitsubishi VS-50703 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
