Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
Several people seem to have this problem. Mine is the same: "standby light" blinking when tv is off and it takes several tries to get tv to power on. Today it took about 20 tries to turn tv on. Help!! I'm no techie so please keep in mind us simple folks.
  • 10 more comments
  • jshanahan Nov 24, 2007
    the TV does not go on but the standby light (timer) blinks ... still TV won't go on. Solutions? thanks
  • Olya Jan 02, 2008
    Same type of problem as previous, clicking on "power" only gets "standby/on" light to flash green for about 30 seconds, then turns back to red (timer), and screen never turns on. Any tips other than loose lightbulb? I know that's not the problem. Ours is 42 inch Sony Wega LCD, more recent model.
  • xessex Feb 10, 2008
    When I switched the TV on it made the usual sound which usually indicates that it is working but the standby light just flashed on and off and nothing else happened - no picture and no sound.
    I changed the batteries in the remote thinking they needed replacing, but that wasn't the problem.
    I then unplugged the TV at the outlet and manually switched it on but with the same result - the standby light just flashed on and off.
    Can anyone suggest anything else to try or is it a case of getting it repaired or replaced? I certainly don't want the expense of either as this TV is only about 4 years old! This is the last thing I would have expected from a Sony product!
  • Anonymous Feb 25, 2008
    TV WONT COME ON ,LIGHT BLINKING 7 TIMES. WENT THROUHG THE OPERATING INSTRUCTIONS THIS DID NOT RESLOVE THE PROBLEM.
  • christabel Mar 06, 2008
    Same problem. Sometimes the TV won't come on at all and the green light just immediately turns red. Once in awhile trying repeatedly will eventually turn it on; often not. Other times it comes on for just a few minutes and goes off. Then it won't come on again. The problem started a few weeks ago and is getting progressively worse. (This is also a 3-year-old, 42 inch model)
  • joseymay Apr 08, 2008
    The tv is, there is sound but the tv is black - there is no picture. The red light continues to blink where it says "stand by timer". We do not have the original controller, only a universal. Tried turning the TV on and off and that did not work. Tried unplugging TV that did not work. Can you tell us how to fix this problem please.
  • pecanwonder May 03, 2008
    standy light blinkling won't turn on
  • phyllis5 Jul 01, 2008
    same as everyone else...standby light blinking...tv won't turn on
  • Anonymous Jul 01, 2008
    have the same problem described above..no sound, no picture, just the blinking timer light...my wega trinitron is 7ys old
  • Anonymous Sep 28, 2008
    stand by light blinking sound but no picture
  • ai-ling logan
    ai-ling logan Oct 10, 2008
    same same -- plug in tv standby blinks @ 12-14 times then repeats 5 blink cycle repeatedly. there is a posted video on youtube of the issue here: http://www.youtube.com/watch?v=sNiyqSio6...
    Have seen other posts that indicate EEPROM error or white balance issue, fixable or junk it? How much might various issues cost?
    This is the first time I have seen the "lamp cover" solution - can anyone post a pic of what this is or describe where its located?
  • Anonymous Jan 14, 2009
    tv will not come on standby light flashes 6 then 7 times and nothing. Tv made in 2004. Sony should have a recall on this model!!
Tengo tv trinitron xbr y tiene sonido mas no da imagen ,el bonbillo de stand by queda titilando que puedo hacer en este caso garcias
harold930@gmail.com : para la respuesta gracias
Posted on Sep 24, 2008
Check your lamp cover and make sure it is not loose. of so take a philips screwdriver an tighten the cover screw.
Posted on Oct 01, 2007
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 11, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trinitron not working
The power supply has failed which are very expense and your better off Getting a new T.V.
May 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinks
The blinking standby light should be in a repeating pattern of a fixed count of blinks. Please post that count here as that will indicate the circuit in which a problem was detected. Armed with that info, we can then tell you the problem and probable solution.
Thanks,
Dan
Dec 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Please post the blink count. The standby light should be blinking a repeated count. That will indicate the circuit where the problem resides.
Thanks,
Dan
May 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
KV-32FS120
Seven Blinks: High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into shutdown. Check power supply and horizontal circuits.
Culbert Communications
New Brunswick, Canada
Nov 23, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
630 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
