We'd like to cut video file from HDD to PC, please let me know how to work. Thanks so much
YOU MUST read your owner manual or download from www.retrevo.com or www.manualslib.com
God bless you
SOURCE: Need unlock code for Toshiba
Ensure that there is no disc in the tray,
Using the remote:
1, Press the “0” button 5 times at approximately one second intervals.
2, Press the “Instant replay” button.
3, Press the following sequence of numbers very quicly (less than one second
intervals) :
If your player is a Region 1 machine, the sequence of numbers to press is 2,
9, 3, 3, 4 and 9 :
If your player is a Region 2 machine, the sequence of numbers to press is 5,
7, 5, 3, 8 and 9 :
If your player is a Region 3 machine, the sequence of numbers to press is 5,
6, 7, 3, 2 and 9 :
If your player is a Region 4 machine, the sequence of numbers to press is 5,
6, 8, 8, 4 and 9 :
If your player is a Region 5 machine, the sequence of numbers to press is 5,
3, 8, 1, 4 and 9 :
If your player is a Region 6 machine, the sequence of numbers to press is 2,
4, 4, 6, 2 and 9 :
4, Open and then close the tray.
SOURCE: Toshiba Hdd/Dvd video recorder. Moved unit
Got the same problem today. I found the solution online on the installation guide. You need to push the two channel changing buttons on the recorder at the same time for 3 seconds.
