2005 Honda VT 750 Shadow Aero Logo
Posted on Apr 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Repsol MOTO Gasoline Motor OIl,4T,Sintetico synthetic blend 10W40
Hello there, I bought Honda Shadow Aero 750 CC from a private sale. It is 2005 and have been ridden 5000 miles.
1. How can i find out if the previous owner used synthetic oil?
2. I just purchased Repsol Moto 4T Sintetico Synthetic Blend oil - 10W40. The box says Gasoline Motor Oil. I need to know if it is ok to use this oil for a oil change on my honda shadow aero. I am not sure if this oil is only for premixing with gasoline only?... Please suggest
thanks a bunch
Anonymous
Level 2:
  • Expert 35 Answers
  • Posted on Apr 29, 2009
Anonymous
Expert
Level 2:
Answers
35
Questions
0
Helped
15579
Points
115
Repsol Moto 4T Sintetico Synthetic Oil - 10W40
Synthetic blend lubricant with high thermal stability, designed to meet the needs of the most technologically advanced 4-stroke motorcycle engines.
  • Excellent starting and lubrication in cold conditions due to its low viscosity.
  • Meets JASO MA API SJ requirements.
Its fine to change your oil with synthetic, Just be sure that you use synthetic from now on... I don't think its advisable to switch back to regular oil after using synthetic.
1helpful
What is the correct oil for Honda Shadow Aero VT 750 2006?
I have used for many years on all my bikes semi synthetic 10W40 oil it works fine. Hope this helps
9helpful
How much oil does a 2004 honda shadow aero 750 hold? I bought my bike used and didn't get a owners manual.
it takes between 3-4 quarts but that model has a dip stick on the oil cap so use it to check as you fill,also make sure to only use motorcycle oil,car oils break down to fast and were not designed for motorcycle use, honda makes a very good oil, i would use a 10w-40 for cold weather and 20w-50 for hot weather,also i would suggest a synthetic oil, it will shift easier and make those movable parts last allot longer. ( preventative maintenance )
2answers
2answers
What is the oil specifications for an 06' Aero 750?
Your best bet is the owner's manual. You can also ask them at AutoZone or Advance auto Parts if you don't want the manual. They will tell you or show you on their chart. This is so easy to do, but you need be careful so you put in the correct oil. Different kinds of oils are used: brake-oil, engine/trans, fork-oil, etc.
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
