Question about Philips 27PT6442 TV
No image, Hear sound, Flashing light
Hey, I bought this TV not working for $25 in hopes that I could fix it and have a decent TV for cheap. Anyways, the TV produces no image, the degaus works, I can hear sound, the light in the front flashes like: 2 flashes pause off 3 flashes pause off 1 long flash The glass fuse inside is good. I couldn't spot any blown capacitors or anything. Anyone got any tips?
  • Omikron Oct 02, 2007
    I did not see any scorch marks. Also, I am not sure how to interpret "BC-327-25=BC-328 BC-337-25=BC-338" I did see some capacitors with "BC" on them but no other numbers like the ones you mentioned.
    Forgot to include the chassis number: L04-1U AA
    Genius:
  • 1,694 Answers
Look for over-heated area on PCB===change 47mf/25v cap and two xistors== BC-327-25=BC-328 BC-337-25=BC-338 This solution is offered for L04-01 chassis.
Posted on Oct 02, 2007
  • Vista Electronics Oct 02, 2007
    Scratch Solution #1 for now.
    You will need senior tech level experience to
    install upgrade kit #483531057673--it is for
    reliable horiz. drive,resulting in HV coming
    on each time set is turned on. Additional
    work may be needed.
SOURCE:
LG LED TV 47ln5790 has no image but has sound. Brief flash of light when powered on and off. I can see image with flashlight.
I saw a youtube video where they replaced the led strips and it fixed the intermittent flashing screen issue
Oct 14, 2017 | LG Televison & Video
Hey! I'm trying to turn on my Sony Trinitron KV27S66 but it flashes the standby light and doesn't show an image. What is wrong with my TV? What can I do to fix it?
Hey there,
Is it set to the correct input?
There should be a button on the set or on the remote called "input" or "source".
If you're trying to watch tv, make sure it's set to Cable, etc.
Hope this helps!
Mar 24, 2011 | Sony KV-27S66 27" TV
I have a cobra 25 ltd classic that I bought from a CB shop it was fixed to have 50 W .you can see all the changes made on it .I have it hooked up with two wips 4 ft 1000 w fire sticks and a power mike it...
either he over tuned it and burned the radio out this can happen just cause a radio transmits 50 watts dosent mean the circuity can handle it and it will burn the radio because of overload. another factor is if you are running high swrs with that kinda out put you will fry it sounds like its getting hot and radios dont work well when they get hot take it to a tech tell him what was done to the radio and what it is doing. you can test the radio by buying a watt modulation meter it will tell you excacley what the radio is putting out I doubt its transmitting 50 watts that is a single final radio unless he modified the final.good luck.
Jan 15, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
How do you fix a tv that wont turn on
sony MDL.KV-32FS210 Tv power light flashing,awaiting signal to come on. neither tv or cable remote wont turn on tv, manual button has no effect. I assume relay inop. Ther is no clicking as I normally hear.
Apr 05, 2010 | Zenith B25A24Z 25" TV
Flashing red center light
With most flat panel TVs, the TV turn itself OFF when it has a fail electronic part and the red light starts flashing. They call this "Protection Mode". The flashing red light should be a error trouble code.
But, it's weird that everything is working and the red light is flashing. Since you just recently bought the TV, I would get it check out while it's still under warranty. Better safe, than sorry.
Jul 20, 2009 | LG 26LX1D 26 in. LCD HDTV
Dtv converter box - low sound
I work for Phillips/Magnavox tech support. If the volume is low like that unfortunately, there isn't anything you can do about it. Coby makes a converter box as well as Memorex, and their boxes had the same problems. The box should be returned to the store for an exchange, or sent in for warranty repair/exchange. There is nothing you can do to fix that problem.
I hope this information allows you to make an informed decision as to how to proceed.
Thank you for visiting FixYa.
May 30, 2009 | Philips Magnavox M61117 (DBM61117)
TV lose image, but it has sound
you have cold solder on vertical IC.
solder all crack contact IC legs
Mar 20, 2009 | Panasonic PVQ-2512 25 in. TV/VCR Combo
Magnavox 27MS4504 clicks, then dies
as always ck for bad connections. slap side lift sid drop  otherwise not worth repair.
Nov 30, 2008 | Philips Magnavox MS2530C 25" TV
Sony tv with no image
When i turn the tv on there's no image and the red light blinks twice each time, but no sound or image or any sign of anything.
Please help me with this problem, my tv is a sony kv-25 with more than 10 years of age.
Mar 16, 2008 | Sony KP-46S25 TV
Sound works but no image
This means the AV cable is not detected, try one of these...
1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
If this is helpful at all, please rate, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
Philips 27PT6442 TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
