Question about Sony Ericsson Walkman® W880i Cellular Phone
Network problem whenever my phone comes out of network area, and back into it(like a drive on a highway) it does not automatically select the network by itself. instead it says to select operator then i have to physically go to mobile netwroks and select network, i tried it in both manual and automatic selction modes but no use.
  • manne Oct 01, 2007
    instead of select perator the exact message is emergency calls only, i then have to physically select network again
  • 490 Answers
Try with following path
Main menu--->connectivity---->Mobile networks-->new search/select network/search mode/preferred n/w ..click on new search, it will automatically select the appropriate n/w... or else restore ur handset ( Menu>>settings>>master reset>>reset settings (default code :0000) )..it will solve ur prob.....
Posted on Oct 22, 2007
Nokia e5 network solution
What you should know is that if you check your phone network settings, it's always on DUAL MODE which means it automatically access Edge and 3G which makes it difficult for the phone to have network on it whenever the area your are has limited network services.
All you have to do is goto Ctrl. Panel (Control Panel) ' Settings ' Scroll down' Click on Phone' Scroll down ' Click on Network ' Now Click on Network Mode ' You will see three types i.e Dual Mode, UMTS(3G), GSM Choose the GSM and immediately you will start having Full network on your phone again, you can follow the same process to switch back to either Dual Mode or UMTS(3G) - See more at: http://www.gistplanet.com/2012/02/solution-to-network-problemissue-on.html#sthash.VWEAxQ3V.dpuf
Mar 02, 2013 | Nokia E Cell Phones
I ve a nokia 2730 classic model ...m using airtel service... when i set umts mode there is no network coverage
This probable if your Network does not have 3G/UMTS coverage in that specific area.
I would set your phone so that it will automatically select 2G or 3G network services (e.g. often referred to as Dual-mode) so that if 3G/UMTS is available and has the best coverage/signal, it will automatically be selected. Setting UMTS coverage only would be very restrictive in many area as the signal is usually weaker (especially in Buildings).
Hope it helps!
Sep 24, 2011 | Nokia 2730 Cell Phone
How to activate grps in touch mobile nokia c300
1 Remove the back cover of your Nokia phone, and then pull the battery out of your phone while it is turned on.
Note: If you experience network glitches, coverage issues, or crackling during a call, it is necessary to reset your phone to reconnect with the cell towers in your local area (which connect to GPRS).
2 Wait a good amount of time for a refresh (approximately 30 seconds), and then put the battery and back cover back on the device.
3 Hold down the red end or power button on the phone to turn it back on.
4 Very that a GPRS icon or text appears in the top indicator bar to make sure you have reconnected to the network and activated GPRS.
Change Network Bands to Activate GPRS
1 Access the phone's settings from the phone's main menu.
Note: In countries outside North America, you typically need to use the 900-MHz/1800-MHz frequency to get a GPRS signal from one of the mobile providers.
2 Move through the menu to locate the network or network setup icon. This might be two clicks depending on your phone model (network > setup).
3 Click on "band" or "phone frequency" to open the menu with the band option.
4 Select the GPRS frequency option, for example, 850/1900, 900/1800 or "automatic" to have the phone choose the strongest band signal for you.
5 Press and hold down the power button to turn off the phone, and then turn it back on to re-establish the connection to the new band if you have connection issues.
Choose a Manual Network Connection to Turn On GPRS
1 Access the main menu on the phone to get to the settings menu.
2 Click the selection for "phone," and then usually there is a follow-up option to select "Operator selection" (based on your model of phone).
3 Select "Manual" to pick a new network to connect to (for international or roaming connections).
Note: Select "Automatic" if you are having connection problems; this will automatically connect to the GPRS connection of your cell phone provider.
4 Verify that your Nokia phone establishes a connection with a network and that the phone works as expected.
Jun 13, 2011 | Nokia 6600
My Phone S3650 shows network error whenever i dial a number or shows message sending failed when i send a message where as it is displaying full signals.i recently got it from saudi arab to another...
Go to menu -> settings -> network settings. Go to select network and set to 'automatic'. Then go to network mode and set to 'automatic'. If this doesnt work you may have to contact your mobile operator.
Mar 10, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
MY Nokia 6610i keeps telling to select network especially if i put it in my pocket.What is the problem?How do i solve it?
i think your phone's network connection is in manual. You should Press Menu, and select Settings, Phone settings and Network selection. Select
Automatic and the phone automatically selects one of the cellular networks
available in your area.
Apr 16, 2010 | Nokia 6610i Cellular Phone
My sony-ericsson z550i display says no network and no coverage area.
go to settings-->phone-->network, try selecting the manual network option, if its able to find a network, you can request register on it, once back to main screen select "automatic" in network so you don't have to search your provider network everytime you loose signals.
Mar 25, 2009 | Sony Ericsson Z550i Cellular Phone
Network Problem in Sony Ericsson G700
hi if u have made an automatic network selection then each time it gets turned whenever u are suppose to go for new environment.. so its better to keep ur network settings as manual and thereby u will be asked everytime if u have a network change..
thank u rate me
Feb 08, 2009 | Sony Ericsson G700 Unlocked GSM Smartphone...
Network disappearing
try changin the network search to manual and manually select the network you are on right now..
if 3G network is availavle, do not choose that.. choose any 2G or 2.5G network for your service provider that wud be available..
if that doesnt work, try to delete all the cookies and stuff from the phone, delete all network settings you got on ur handset, and ask your service provider for the settings again..
Jan 29, 2008 | Nokia 3250 Cellular Phone
CONTINUOUS SEARCHING FOR NETWORK
change the settings to automatic network selection
if still the problem exists
then contact ur service provider
Oct 28, 2007 | Samsung SGH-E900 Cellular Phone
Network and battery problem
For network problem you have to go to the connectivity through your menu and select mobile networks and change the mode to automatic and then in mobile networks check out with prefered network option.
Aug 12, 2007 | Sony Ericsson W700i Cellular Phone
Sony Ericsson Walkman® W880i Cellular Phone Logo
126 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
