Question about Dell E153FP 15" LCD Monitor
To dismantle the dell e153 15 inch monitor
Please i want to open the Dell E153FP 15" monitor but i dont find any screws please teach me how to open the lock that is only my problem please help
  • alex1099 Feb 04, 2008
    I have a dell 1907fp monitor and need to open this up. Can anyone suggest how as I am confused as where to start prying it open. Do I need to do anything to the padlock slot on the back at the bottom?
  • Anonymous Feb 23, 2008
    try to open case of dell e151
The front and rear of the case is held together with latch and hook type fasteners, this is how I cracked mine apart.Remove the 4 screws holding the stand on the back of monitor, start with either bottom corners and insert a flat head screwdriver or similar soft object such as a wooden popcicle stick into the crack and work your way up the side to the top, then across the bottom, and up other side to top, I then ease the case apart at the top with no effort.
Posted on Feb 21, 2009
Slide in a flat headed screwdriver into the side of the monitor in the join of the plastic and gently twist it to push both sides of the plastic apart
Posted on May 30, 2008
The answer is not clear to me pry means is the locks to press down and apart please explain me in very simple way. I did understand but pry apart that is still not clear to me explain in detail
Posted on May 25, 2008
There are no screws. Believe it or not, you have to pry it apart, and some of them can be pretty difficult! :-)
Start at the bottom where you see the small squares and gently pry that apart. Then you move up the sides, I slide a flat bladed screwdriver up an unsnap the catches, they can be pretty tough.
Posted on Jan 31, 2008
Is There Hidden Microphone on Dell E153FP 15?
No, this is juat a basic 15" LCD monitor.
You can see the inside of the monitor here:
Oct 18, 2011 | Dell E153FP 15" LCD Monitor
My dell monitor have not backlight. what's problem and how i can repair it? Thanks.
Usually Dell monitors have a 3 year warranty, hence check with Dell. If your monitor is out of warranty this problem can be fixed by a tech who can open the monitor and replace teh backlight or the backlight circutis.
Dec 26, 2010 | Dell E153FP 15" LCD Monitor
The screen on my computer (dell E153FP 15" lcd) keeps going black everytime I turn it on. I can still see a very dark picture and the green light is still on but I can't see much. Usually I just turn it...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Replacement bd.
May 20, 2010 | Dell E153FP 15" LCD Monitor
I'm trying to hook up the e153fp to a dell latitude lap top. What are the settings that I should use for this configuration? the e153fp doesn't like the display settings.
By going to I was able to pull up the user guide for the E153FP and read the specs to determine that the monitor has a screen resolution of 1024x768. The previous monitor had a higher resolution and this is why the E153FP would not display correctly.
Thanks for your response to my posting.
Nov 02, 2009 | Dell E153FP 15" LCD Monitor
Message error
Can you mention the exact error message that appeats on your screen.
Jun 19, 2009 | Dell E153FP 15" LCD Monitor
Dell E196FPf monitor power problem
generally dell monitors open from the bottom they have slight indented flat spaces for a small flat head screw driver to twist and pop the frame apart I start on the bottom left and work my way right and then open the sides carefully and last the top.
Please rate if helpful
Jan 14, 2009 | Dell E153FP 15" LCD Monitor
Dell E153FP monitor
I have a Dell E173FP LCD, my monitor don't want to stop showing his Main menu , I had the problem since 3 months and didn't get a solution for it , some time it keeps showing the main Menu without stoping ,sometime not...crazy monitor.... But i have a friend that faced same prob and toldme to open the it and see inside it if there is a detached cable or anything...just don't know how to..please tell us a soultion.
Jul 06, 2008 | Dell E153FP 15" LCD Monitor
Dell monitor wh 320
Just done mine and the plastic case/frame is secured with clips all the way around.
Remove the stand/bracket screws
Place the panel on its top edge and look down on the underside join.
You will see two small notches where you can get a pen knife/lever in. Dont poke in too far especially where the buttons are.
Now lever the back off the front by leaning your knife/lever in the same direction as the screen front. Once you have the first clips free you can work all the way around in the same way taking care not to damage the plastic much.
I hope that helps someone else who is stuck like me at first and found this Q unanswered and eventually I decided I had nothing to loose lol.
Aug 22, 2007 | Dell E153FP 15" LCD Monitor
Lcd monitor goes white
The E151FPb's seem to have a problem of this sort. After doing some research online I've found that the most common problem is a few dry solder joints on the large circuit board inside the monitor. There was also some talk of a connector suffering from heat creep that sound be connected better on the inside, but usually that would make the screen turn black if it were to become disconnected. The monitor can be opened by unscrewing all the screws on the back, there should be 6 screws you need to pull out before being able to open the case. After those, insert a thin, but strong piece of metal into the side and sort of twist/slide it along the side and it should pop open some clips and just work your way around the perimeter. After that it's just some simple and obvious screws to get to the circuit boards.
Apr 11, 2007 | Dell E153FP 15" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
2,736 people viewed this question
Alun Cox
