SOURCE: Kicker compVR 12
get a ground loop isolator. and another set of rca's or just run the power wire on the other side of the car let me no if that helps please rate if help full or not
SOURCE: what is the recommened air space for kicker comp
Really it all depends on how you want them to sound, and to be set up. There really is not specific air space, but there are general air spaces that work, and some times the manufacture will list some specs for different set ups. It also depends on the size of the sub, which you did not specify.
Kicker recommends as follows.
0.4 cubs per sub for a compact box, and 1.8 for an SQ box. SQ stand for sound quality.
So if you want a small box, do .4 per sub. If you want a better sounding box do 1.8.
Rule of thumb and something to think about.
The more air space in the sub, the less power you can run, the less air space, the more power you can run.
For example you can run 200 watts RMS per sub at .4 cubes, but only 140 watts RMS with 1.8.
As well, the smaller box will be louder, But not sound as good.
Testimonial: "thaks that cleared up the questions i was having"
SOURCE: I have a Kicker comp
You will want to use official speaker repair glue, which can be found at this link:
http://www.amazon.com/gp/product/B0002ZPUGW?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B0002ZPUGW
And yes you want to apply it all the way around the rim of the spider to ensure that it stays together as well as possible. Subwoofers are very tough to repair since they move so much,, that is why Kicker will not repair them. If you purchased it with a major credit card, call your credit card company and see if they have an extended electronics warranty. They may just replace it for free for you. Most credit cards do this.
Thanks
Tim
SOURCE: i have a 2011 gmc sierra and im putting a kicker
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch sub the box size will be 13 inches x 13 inches x 13 inches. Hope this helps
SOURCE: kicker comp 12'' subwoofer swingarms snapped
when you say swing arms i assume you are talking about the wires connecting the terminal (where you connect the wires to the sub) to the voice coil (the center of the sub).
If these are broken it is tricky to solder new wires back on. If your sub is still under warranty i would suggest sending it back to them. below is there number and business hours.
Kicker Customer service Email: [email protected] Phone: $05-624-8510
M-F 8AM-5PM Central Time
