Question about Bose Lifestyle 48 System
Bose Lifestyle 48 Error code 801
Hi, I have a bose lifestyle 48 system and I am having some toruble with it. It is not able to play stored songs and the message displays error code 801. Appreciate if someone can help. Thanks Rohit
  • 4 Answers
We had this problem. I called Bose, and they reported that the 801 error is a hard drive problem. The unit started squealing while I was on the phone to support, and the guy heard it. Said the hard drive was failing.
$200 to ship the unit to Bose to replace the drive. Wish they had a secret warantee for what seems like a common problem.
Posted on Jan 13, 2008
  • 3 Answers
Just purchased the hard drive off of impact computers.com will see if it works or not i would rather take a chance and spend 100.00 then give one more F@#$ing dime to bose and thier muthr f%$#ing azzes. will post the answer if it works or not in 2 days when it gets here. 03-18-2010
Posted on Mar 19, 2010
  • 1 more comment
  • jbarbieken Mar 23, 2010
    Well brothers and sisters i have done it! F(*&K Bose. go to Impact computers and electronics the hard drive you are looking for is the mk4026gax this is a take out and install all by yourself easy and quick and bose does not get another dime of your money!!!! remove 6 screws from bottom pull top off from back first carefully hard drive is on the left side just pull a bit and it comes up remove 2 screws from bottom pull off ribbon install new hardrive!!!! wham bam F)(k you bose... It works great!!!!!!
  • Hyperacin Sep 26, 2010
    Are you now able to store music again with the replacement drive?
  • s16724 Oct 06, 2010
    did you have to format the drive or just install it out of the box
Bose lifestyle 48 won't play stored music. Everything else works fine
Hard drive is ****..... impact computers.com hard drive number is MK4026GAX pull out of system and replace look at my other posting for 801 code!!! and dont be a ******** again and buy a bose!! TELL YOUR FRIENDS , FRIENDS DONT LET FRIENDS BUY BOSE!!!!
Mar 19, 2010 | Bose Lifestyle 48 System
Tip
Reset Bose LifeStyle 48 VChip Password
Bypass or Reset Bose LifeStyle 48 System V-Chip Password Lock
Would you like to bypass, defeat or reset your Bose LifeStyle 48 System Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked signal without entering your password.
When your passcode is requested, enter the temporary code 2673. This process temporarily unlocks your system, and you can reset or change the password.
I hope that helps.
_______________________________________
Bose LifeStyle 48 Manual Download
Bose LifeStyle 48 Video Mode
on May 02, 2010 | Bose Lifestyle 48 System
Tip
Download Bose LifeStyle 48 System Owners Manual
Have you misplaced your Bose LifeStyle 48 System Users Guide?
Would you like a digital, searchable, pdf version of the Bose LifeStyle 48 System Owners Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on May 02, 2010 | Televison & Video
Same problem LS 38< two years, error 802, unplug and erase umusic
Sounds like hard drive is failing, 802 and 801 is hard drive problem. i have same problem. only fixable by bose repair man... tryed to change hard drive myself, changed over, looks same as playing but no sound. hope this helps:) common problem with bose other than that i have had not other probs.
Jul 10, 2009 | Bose Lifestyle 48 System
Bose lifestyle fault code 802 hi there- i have a bose lifestyle 48 and on display it reads format unsupported when i try to listen to cd's gut not on dvd's - in addition i am unable to store music into the...
Unfortunately, an 802 error is bad. That means hard drive (HDD) failure. This can happen to any hard disc drive, and there's no way to predict it and no way to fix it from home.
If you even try to troubleshoot it (reset etc), you could loose more data (music you've already stored to the system). If you try to access 'stored' music- the error will continue. Also, every time you turn the system off, it checks your HDD, and will probably cause the 802 or 801 errors to display again.
The "Format Unsupported" message may be related, but usually temporary. The 802 (and also 801) errors mean irreversible HDD damage so it doesn't matter.
Call Bose tech support immediately.. They can repair it for $165 and give a new 1 year warranty. And if it's already under warranty they will repair for free. In either case they will replace your HDD with a new one, and transfer any salvaged music files from your existing drive to the new drive.
May 31, 2009 | Bose Lifestyle 48 System
Tip
I hope that helps.
Bose Lifestyle sound system shows "Failed 801"
your hard drive is about to fail or has failed.
If you can still play music from stored area and If you want to keep your songs thats stored on system, turn off at power point and take to bose auth repairer, they should be able to transfer songs across to new hard drive.
I have same problem, this is a common problem with bose.... not good for how much they are. Hard drive is left of cd tray, on its side.
hope this helps :)
Mar 29, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
System does not work
try update cd,,,, i might work..
if its hard drive normally says error code, might be somthing like mother board...
Sep 22, 2008 | BOSE48 - Lifestyle 48 Home Entertainment...
Life style error codes 801 & 802
Hi, I had the same problem, they had to replace my harddrive and the dvd, lost all my music, 145 cds, just got it back, it now works fine,
good luck
jps
Dec 31, 2007 | Bose Lifestyle 38 DVD Home Entertainment...
Aladinom
Call Bose. It needs a new hard drive. There's a charge if it's out of warrantee, but it is reasonable. Seems like this is a common problem!
Oct 27, 2007 | Bose Lifestyle 48 System
Bose Lifestyle 48 System Logo
1,997 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
