Back to:
Tags:
E-Machines EMA IMPERIAL GV  TG3 eMachines  Motherboard
Non response from tower
posted by paul d on Oct 01, 2007
I have just tried to power up an old emachine
but no luck... i checked the psu and found it to be dead so i changed it with a brand new one , when powering up this time the processor fan run very slowly and nothing else, no beeps or anything not even a flicker on the screen i would say the psu going the first time also took out the motherboard.
I have checked all capacitors everything is fine and i can find no burn out on the motherboard itself....is it worth repairing or will it have taken the cpu and memory out as well
Comment by paul d, posted on Oct 02, 2007
Thnx for the reply the pc doesnt owe me anything and the psu i always keep a spare so i think retrieve the hard drive and as i have no way of checking the rest i think the bin is the only option..........Thnx again
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
acidfish
Rank:Master Master
Rating: 86%, 29 votes
If you're hoping for a bargain out of it, it depends how much your time is worth. Given that the PSU was dead, and other components are showing problems, one or more of them were probably affected. Could be the fan is spinning slow due to damage, and the motherboard is refusing to fully init because of the fan... but I doubt it.
The CPU may or may not be okay, but the value is likely to be low. The RAM is probably okay, but again, value is likely to be low. Your best bet would be if you had a second similar computer, to try interchanging parts and see which are damaged/working.
In general, though, the system probably is of very low value when working. It looks like it may be model T3624; if so, a model recently went on eBay for $140 (including shipping), in working condition and with 512mb RAM. (item 190155139483)
Personally, I would try to sell it as-is for $75, with the dead PSU, or the amount you paid for it (if applicable). Depending what the PSU cost you, you could also add that to the price and ask for that, with the working PSU.
At the end of the day, the question becomes, how much would it cost to buy this computer (or a similar model) in known working condition? Is the value of your time, or replacement parts, going to exceed that?
Rating Locked! (?) paul d has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on non response from tower:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
E-Machines EMA IMPERIAL GV (845GV) TG3...
I had sound before I installed comcast high speed internet...
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
