Question about Kitchen Ranges
Indesit H561IX Cooker hood stopped working
Not working after 'bang' sound from underneath the area of the switches when switched on. Have changed fuse (just in case) but still not working. Now at the limit of my electrical knowledge.
2 Suggested Answers
  • 72 Answers
SOURCE: Cooker hood H561IX Not working after 'bang' sound
If you have changed the fuse it sounds like a loose wire in the switch or the main fuse in the fuse board has blown.
Posted on Dec 28, 2009
Today my fan for the air quit working. Where should I look to fix problem
Try banging your hand in around the passenger dash area. Sometimes this will make a defective blower motor work. It ca be a fuse, resistor,blower motor, switch or wiring causing this issue
Apr 14, 2015 | 1998 Buick LeSabre
The windows aren't working on my 2007 Jeep Compass?
That should be a fuse or master control switch/relay if all are not operating, otherwise it could be a flood car. If it were only one or two windows I would suspect a defective motor which in some cases will start working when you bang down low on the inside panel while pressing the switch. Another possibility is one of the smaller hot wires on the battery or going into the fuse box is loose.
Mar 13, 2014 | Cars & Trucks
Sony TC377 Tape Deck - switched the deck and left a reel to run but did not work - few minutes later there was loud bang and smoke coming from the fuse box area. Disconnected the power supply. Is it
It is hard to determine a repair cost with a description like this but sound like a capacitor blew and that should be obvious when it is looked at. Probably took some fuses and a bridge rectifier with it or it might even be a motor run capacitor- you need to tell us which caps blew up.
Jan 31, 2013 | Sony Audio Players & Recorders
Power windows are not working. I checked the lock switch and it is off any idea which fuses control the power windows I checked fuse 4 of the fuse box in the engine area.
when you pull the cover off the fuses you should see a label under every fuse. also you r vehicle book will have a diagram also. Worst case you can pull every fuse one by one to find a busted one.
Jan 27, 2011 | 2000 Mercury Mountaineer
I lost my brake lights, turn signals, and hazard lights. The car will start but won't go into gear.
Sounds like a blown fuse...i would be checking the fuse panel inside the car, underneath the steering wheel area on the drivers side...this would be an interior fuse that would also control the brkae override switch.....
Jan 05, 2011 | 1996 Ford Thunderbird LX
My rangemaster cooker hoos has just stopped working.. no fan working and no light coming on ??
The same happened to me. I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Dec 20, 2010 | Rangemaster Kitchen Hood
Indesit washing machine W1A 121 no red light when
Select reset from front panel and reset timer. you may needalso to cure water level fault as its overfilling. could be dirty air hose to pressure switch...
Nov 13, 2009 | Washing Machines
Zxr400 import, headlight works/doesn't work for no apparent reason, have changed fuses/battery/bulbs
How about the light switch or dimmer switch itself? This is old enough to have corrosion in the switch contacts from water entry. Try spraying WD-40 into the switch and operate it several times. Also, look into the headlight case area for corroded connections (light socket too) or loose connections in the wiring harness. Does the taillight wink on and off with the headlight?
Jul 23, 2009 | 1991 kawasaki ZXR 400
Kitchen Ranges Logo
314 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
