Question about Jenn-Air JGS8750 Gas Kitchen Range
Jen-air gas range
I am getting an error message F1-7 on the screen and says call authorized dealer. It constantly is beeping and when I turn the oven on at about 325 it turns itself off in a few minutes. Right now it isn't working at all. We keep on pressing the cancel button bit it does no good. We were told to shut the power by cutting off the circuit breaker and re-starting. For a short time it worked, but now it is the same as before. PLEASE HELP.
  • cheerdad Nov 04, 2007
    I have a code f1-7 coming up on my oven and it will not turn on. Help.
    model number jes9800aaw serial number 13045392zm
  • Vic_needhelp Nov 04, 2007
    I also have the error code F1-7 for model number JES9750AAW, serial 18940627EG. The range just started beeping and code F1-7 comes up with call service. We had the whole button panel (they said it was one piece) replaced it cost a staggering $500.00 to have a technician replace it less than a year ago. Now if I look up code F1 it says to replace the panel again (can not afford it). However I can not find the meaning of code F1-7. I read it could be the temerature probe. Is there a way to test the probe before I replace it? Has anyone had this code and what was the solution or what fixed it? Thank you, signed Jenn-Air poor
  • 473 Answers
Look on the back of the oven for a tech sheet. This will tell you what these codes mean. It may be the oven temp. sensor that is bad and they are easy to replace. Sometimes they check ok at room temp. but fail at higher temps. and will shut the oven down. The temp. sensor is usually in the upper left hand side of the oven and looks like metal probe about 6-8 inches long. Hope this helps.
Posted on Oct 06, 2007
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Oven does not work f3 in the screen
Oven control beeps and displays any F code
error (for example F11).
Electronic control has detected a fault condition. Press CLEAR/OFF to clear the display
and stop beeping. Reprogram oven. If fault recurs, record fault number. Press CLEAR/
OFF and call your dealer or authorized service agent for assistance.
Dec 17, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Constant beeping and F7 is displayed
Hi tahitian,
The error code F7 means that the Function key is shorted or stuck. To fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Dec 16, 2008 | Magic Chef 31000 Gas Kitchen Range
Error F1E2 Whirlpool Super Cap Gas Range 465, oven crazy!
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Nov 22, 2008 | Whirlpool GS460 Gas Kitchen Range
Front control panel shows "Remove Probe From Oven" & Beeps.
I have the issue as well, seems like when I use the convect. feature. I have not called to have it serviced yet, but I have found that opening the oven door and truning the fan on for a few minutes, corrects it. At least until you turn it off again.
Sep 23, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Error code
I have a jenn air range gas cooktop electric oven model # svd48600b the convection fan will not turn off and when you attenpt to use oven an error code F-3 appears and beeping sound what part is defective?
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
F1-8 commonly means shorted membrane. Unplug or shut off the circuit breakers for 15 minutes, plug back in/turn back on, if problem persists replace membrane, if they are integrated parts replace control board (some come with membrane on parts vary)
Always shut off power before any repair attempts electrically
May 01, 2008 | Jenn-Air JGS8850ADS Gas Kitchen Range
Jen air locked latch after cleaning
I finally got my oven to work properly by shutting off the breaker and resetting the main clock. Cured the always locked problem as well as the beep twice when self cleaning.
Have to repeat this every few months since the problem seems to come back.
Feb 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air Gas Range
F1 is a bad power relay board.
F8 is a shorted meat probe alarm (probe jack or the harness to the probe jack)
Dec 19, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
There are generally three reasons for this. 1. The oven latch may have been moved, even slightly from the locked position. Check to see if it is stuck and not moved all the way to the right. The mechanism may be clogged due to grease, or other foreign matter. 2. You have an error code. Touch the Clear/Off pad. 3. Disconnect all power to the range and wait 5 minutes. Then reconnect the power. If that does work, call an authorized GE service  company for repairs.
Dec 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Jenn-Air JGS8750 Gas Kitchen Range Logo
435 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
