Sharp plain paper ink jet fax ux-b750
Hi,I need to know how to set the fax up so when someone calls my phone it will go to my voice mail and not the fax.And also the fax will work when i am reciving a fax and not the voice mail.Thank you, gary
  • 1 more comment
  • hummel Oct 02, 2007
    Yes please,I sure do need help setting them up.Thank you
    If all fails can get back with you later.
    This fax has a RESOLUTION,RECEPTION,FUNCTION,PRINT HOLD,SPEED DIAL,HOLD,SPEAKER.Ithas a START MEMORY.So far it does not work.
    Sergeant:
  • 279 Answers
Many fax machines have an auto select mode that will answer the phone and listen for a fax machine, but if there is no fax machine it will cause the phone to keep ringing so you can answer the voice call. Your fax does not have that feature. The closest you can come is to set it to manually answer, and then set the fax to kick in automatically if it hears anything. The problem with this is, if you don't answer the phone when it's a fax, the fax machine never kicks in. I don't think that's what you want. The other option is to turn that feature on, but leave it as auto answer after 5 rings (the maximum for your phone). Then answer the phone before 5 rings if you're there. The problem with that is, anyone who calls when you're not there (or if you don't answer within 5 rings) will get your fax machine beeping at them. Do you need help with either of those settings? Let me know if you do, and I'll give you directions on setting them up.
Posted on Oct 02, 2007
  • Anonymous Oct 02, 2007
    To set it to Fax or Telephone mode (Fax mode means it answers, Telephone means it doesn't) just hit the RECEPTION button while there is no paper loaded where the originals you want to fax go. This will toggle between the two modes.
    To set number of rings, press the Function button then the down arrow 3 times. Then Press Right once, then Down once, then right one more time. Then hit the number of rings (for instance, a 5 for 5 rings) on the number pad. Then press the Stop button.
    To set Fax Signal receive (the fax machine will kick in if you pick up the phone and it hears a fax machine on the other end), press Function, then Down 3 times. Then press Right once and Up 7 times. Press Right once. Then press 1 to turn the function on, or 2 to turn it off. Finally, press stop.
    If you follow all the above directions, and leave it in Fax mode, the phone will ring 5 times. If during those 5 rings, you pick it up, and it's not a fax, you can talk. If you pick it up and it is a fax, you'll hear the fax try to communicate, and you can hang up. If you don't pick it up, the fax machine will assume it's a fax and try to answer after 5 rings.
    This is as close as you can get to the fax machine only answering fax calls with this model.
  • Anonymous Oct 22, 2007
    Did you try any of the settings I suggested and outlined in my second post?  If anything is unclear, please let me know what and I will try to clarify.
    President:
  • 2,961 Answers
To stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
SOURCE:
Fax stored in memory; how do i print?
Hi
first make sure you have paper and ink in the fax. If you do, then unplug it for a min. It will hold the memory when unplugged. When you plug it back in it should print out.
Good luck
Dec 31, 2010 | Sharp UX-B750 Inkjet Fax
I want to know if I can use regualar paper
If it is a plain paer fax you can use ANY paper you would use in an injet printer.
Apr 07, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Install a refill UX-B750 cartridge but display still showing out of ink.
The machine is not identifying the cartridge properly. Attempt to reinstall the cartridge. It just may be installed incorrectly.
Dec 09, 2009 | Sharp UX-B750 Inkjet Fax
Sharp UX-B750 won't automatically answer calls.
Your reception mode is set to TEL/FAX or TEL mode, to set it to automatically receive faxes it should be set to FAX. Look at the LCD display ( right section ).
To change the reception mode you can print the HELP LIST by pressing COPY/HELP button.
May 26, 2009 | Sharp UX-B750 Inkjet Fax
Refilled cartridge problem
There's some kind of a chip chip in the catridge that notifies the printer that the same cartridge has been refilled. to get around this check keep atleast 2 or 3 empty cartridges, refill and cycle them. That should do the trick!
Dec 02, 2008 | Sharp UX-B750 Inkjet Fax
I have a sharp fax ux-b750 and i the maual help
Hi Mike - Below is the link for your manual. It's the British version but everything is the same. Just click on download and then on agree. When the download box opens just save it to some place you know where it is. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://esupport.sharp.at/html/om/DataOutputDetail.php?TemplateLang=en&ID=11571
Jeff
May 22, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Out of Ink
Did you get any help with this issue? My machine is giving me a "cartridge error"...I can't seem to get it fixed.
May 15, 2008 | Sharp UX-B750 Inkjet Fax
Check Cartridge Error - Sharp UX-B700 Plain Paper Inkjet Fax
I replaced my new $40 cartridge with another new cartridge and it worked.
Feb 23, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp UX B20 Plain Paper Fax
http://www.sharpusa.com/files/fax_man_UXB20.pdf hope this helps Cops
Oct 07, 2007 | Sharp UX B20 Plain Paper Inkjet Fax
108 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
