Question about Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 issues
Sony Cyber-shot DSC-W50 Digital has flashing on screene 91.01, and the flash doesn't seem to responed, Thanks in advance Tim
Re: Sony Cyber-shot DSC-W50 issues
Great explaination.
I tried this reset, but the error came back. Read in other posts that it is a "flash capacitor" problem.
Posted on Apr 15, 2009
  • 74 Answers
Hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
Posted on Oct 17, 2008
0 characters
3 Points
I have a Sony Cyber-shot Super Steady Shot DSC-T10. I have 2 babies under 2 years old and every time they are doing something adorable I can't get the shot because my delay on my camera is so long they are...
It seems the Red-eye reduction feature of the flash is ON. In this mode, the camera emits a pre-flash and then the actual flash discharges after a delay. Or it could be on Slow Sync. In this, the flash fires at the end of the exposure. Just go to Flash modes (the lightning-like icon) and if it is showing an eye-like icon or the word 'slow', change it to some other mode, probably the flash ON or OFF mode. Also, make sure that the batteries are fully charged.
If this solves the issue, please rate this solution.
Sep 02, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Flash won`t work
Error ( E:91:01) is off COMPLETE FLASH UNIT which contains part No. along with description is given below:
A-1166-208-A ST-133 BOARD, COMPLETE
(For DSC-W50)
A-1231-877-A ST-133 BOARD, COMPLETE
(For DSC-W55)
For your convenience please see the pic below of required part:
7985bce.jpg Thanks
May 30, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
this is my same problem in my Sony Cyber-shot DSC-W130., pls e mail me if someone answer your problem., this is my e add --
Dec 23, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cyber-shot dsc-w50 problem
It's a flash error. Could be flash fuse or flash board. If you have a multimeter and you're ready to open it, contact me at or contact your local Sony service center.
I work in a Sony service center.
Jul 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
When “FLASH error” (Self-diagnosis Code E : 91 : ** ) occurs, to prevent any abnormal situation caused by high voltage, setting of the
flash is changed automatically to disabling charge and flash setting.
After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the Setup screen.
Method for Initializing the Flash Error Code
Initializes the setting to the default setting.
1 Select [OK] with v on the control button, then press z.
The message “Initialize all settings Ready?” appears.
2 Select [OK] with v, then press z.
The settings are reset to the default setting.
• Make sure that the power is not disconnected during resetting.
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
might be the software could be corrupted try reinstall the software r go to the nearby sony world
Oct 25, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Flash does not turn on
A camera malfunction has occurred. Reset the camera, then turn the power on again.
Reset button is under battery lid.
Feb 13, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Flash is inconsistent
I have the same issue. One picture the flash is perfect the next there seems to be a "half" powered flash and the pic is dark
Dec 09, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
233 people viewed this question
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
