Question about Refrigerators
Ice Maker problem 106-626636
I have a kitchen aid fridge ksre25fhwh02. The ice maker worked fine, I disconected it for two weeks and remodeled the kitchen. I ran a new water line, now it wont work. There is water in the door, when the water arm is touched. How do you manually cyclr this ice maker, to see if the water valve is opening, or if the heater comes on, and the motor turns? Thanks, Stu
  • 4 more comments
  • dstgst May 04, 2008
    106 626636 icemaker. mold tray empty. does not fill water and motot is trying to advance ejector arm all the time making noise indicating resistance of some sort. unpluged it, disconnected and removed module cap. "do not manually turn" gear can not be turned at all. removed a motor. little motor gear can not be turned at all manually.
    Assembled it all back.Set arm in on position, jumper L and V it filled the water. Jumper T and H and it made full turn. Ejector arm is outside the mold. Is it safe to give it a couple hours to freeze and go thu the cycle??
  • Grandpaw1 May 20, 2008
    ice maker will freeze ice however it will not dispense ice in the ice bucket.
    I pressed the button and the ice tray will turn and dispense the ice and the water
    will refill the ice tray but it will not automatically work I checked to make sure
    the button in front of the refrierator the ice button is on any suggestions?
  • rbigham357 Jan 08, 2009
    I jumpered L-V and the water filled. When I jumpered T-H, nothing happens. What does this mean. I have a Whirlpool ED25RFXFW01 Side by Side
    thanks
    Rick
  • rifners May 03, 2009
    I jumpered l-v and my tray filled, however when i jumpered t-h nothing happens. What do i do now?
  • Joe Rocket Jun 10, 2012
    I'm having the identical problem. I've replaced the entire module but still no results. What should the voltages be at the connector where the module plugs into the icemaker?
  • Anonymous Mar 25, 2014
    I remodeled my kitchen and removed refrigerator with ice maker do I need to bleed the air out ice maker when I reconnect?
  • 447 Answers
Pull the front cover off the i/maker. There are holes on the module(the piece with the large gear) They are labeled T an H at around 5 oclock L and V around 6-9 oclock use a piece of wire to jumper l and v first it should start to fill if it doesnt the fill tube may be iced up, if it does fill then jumper t and h for about 6-10 secs or until it will advance by itself. Also whirlpool had a batch of faulty modules the large gears were breaking if it wont advance or if the plastic gear falls off easily then this is the problem. Dont forget to rate my solution!! Thanks!!!
Posted on Oct 02, 2007
  • 2 more comments
  • Fixya Sucks Nov 10, 2013
    You just saved me buying a new icemaker. Thank you kind internet person!
    You just saved me from buying a new icemaker! Thanks Joey
    Uh yeah, didn't mean to do that twice. I was drunk from an iced martini using ice from my newly fixed icemaker.
  • tel elquist
    tel elquist Jul 24, 2014
    Great idea worked great!!!!!
Thanks for the tip!!
Posted on Sep 30, 2008
Great information!
Posted on Jul 13, 2008
SOURCE:
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
KITCHEN AID REFRIGERATOR PROBLEM We bought a used Kitchen Aid fridge YKSRS22Q (1993), the ice maker is not working but water does work. What should we check to see why the ice maker doesn't work?
Ice makers work off of temperature. If it's not cold enough in the freezer it won't work. Check the temperature with a thermometer, it should be 0 to +10F
Jan 29, 2011 | Refrigerators
I have a kitchen aid fridge and my ice maker stop producing ice i tried turning off the ice maker switch for 30 seconds and on again waited 24 hours and nothing what else can i do to resolve this issue.
You can use this ice maker manual to trouble shoot and repair your ice maker.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f6bad9d0e44bf81d852573e900695d73/$FILE/8178689%20%28Icemaker%29.pdf
Jul 09, 2010 | Refrigerators
Have kitchen aide fridge ice maker stoped working, replaced ice maker still not working, red light blinks twice? Help
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hkhjkd
Jan 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid ice maker is making a pumping noise. The noise is itermitten. It still makes ice. Freezer is at 5 degree and fridge is at 34 degree. Aquasensor filter is at 44 percent left. Thanks...JA
noise from ice mker can only be the ice maker unit... turn of icemker for a while and see if tn=he noise comes on during that period . if not replace ice mker head . mm
Dec 07, 2009 | Dishwashers
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
8,646 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
