Question about AEG LW1250 Front Load Washer
AEG L1250 Washing Machine
I used the washer last night, this morning there are no lights on the front panel,(just as if the plug was pulled) however, I have removed the lid and there is power to the machine, any suggestions
  • yoshi san Sep 01, 2008
    the on off switch is lit but the digital display is not.  the machine will therefor  not start any programme
  • 209 Answers
Possible interlock, the switch that stops it from working when the door / lid is open start here
Posted on Oct 02, 2007
SOURCE:
My aeg lavamat L washer/dryer has suddenly stopped working and there is no power
Sorry this isnt a solution .. Im just wondering if you did manage to get this sorted as it happened to my machine this morning?
Feb 17, 2012 | AEG Lavamat 16810 Front Load Washer/Dryer
My washing machine won't turn on, I moved it last night a couple inches and now it won't turn on.
check washing machine wire plug. turn it open and check the wires.
are they fix accordingly.
Dec 12, 2011 | Kenmore 44102 Front Load Washer
I have a Bosch SHU3036UC dishwasher. While sitting idle - during the day or over night, it fills up with fresh water. I shut off the water supply last night and this morning it was dry. Any ideas?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 12, 2011 | Bosch SHU3036UC Dishwasher
My machine is 3 years old and used on average four times a week. It not worked hard as we work in offices, so no heavy overalls. Last saturday it stoped half way thru a washer cycle. The door remained...
Easy, scrapped it and purchased an Indesit. The cost to repair AEG was more than buying a new machine. I would suggest to anyone reading this never invest buying AEG unless you have a live in washing machine engineer.
Jan 26, 2010 | AEG Washing Machines
Remove front panel on ge washer
Use a putty knife and press in the panel clips located on the top left and right sides where the front panel meets the top lid. They are about 3 inches in from each side.Press on the clips while pulling forward on the front panel.
Jul 25, 2009 | GE WBSE3120B Top Load Washer
Old whirlpool washing machine won't run.
if no lights suspect main control bd remove rear screws in top panle remove top by sliding towar back control is along rear
Jun 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
AEG lavamat 6955 showing F9 on display panel
unplong machine and restart it .eamonn eire thank you
Jan 26, 2008 | AEG Lavamat 88840 Front Load Washer
Trips out the mains fuse.
must be an earth fault within the machine. suspect a burned out wire or switch. possibly carbon dust within the motor. take the top off the machine & have a look at the wireing loom.
SWITCH THE POWER OFF FIRST
Oct 21, 2007 | AEG Lavamat 72640 Front Load Washer
AEG LW1250 Front Load Washer Logo
277 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
mikenearman
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
