Question about ASUS A8N-SLI Premium Motherboard
Usb 2.0 problem
Hello. I have some problems with my ASUS A8N-SLI Premium... If I turn off USB2.0 Support on the BIOS, pendrives and external hard disks work well but in low speed. But if I turn on USB2.0 Support, then my Windows XP with SP2 don't recognize them. I need some help! Thank you!
  • cyane Oct 02, 2007
    Thanks for your help. I don't have the two options, Full speed and hispeed. And i don't have the cd because my motherboard is second hand and the previous owner didn't send me the cd. I've checked the Asus's website but i didn't find the usb drivers...
The cd that came with the A8N Sli Premium motherboard does not contains USB 2.0 Driver but instead has a note saying that the drivers are in Windows Service Pack 2
Posted on Mar 17, 2008
  • 21 Answers
If you do turn off USB 2.0, you may have two options, "Full Speed" and "HiSpeed". Make sure you use "Full Speed", as it's faster than "HiSpeed". But the real answer is that you need to install the USB driver for your motherboard. If it came with a CD, insert the CD and read the instructions on installing drivers from it; otherwise, check Asus's website under the Support/Downloads section.
Posted on Oct 02, 2007
SOURCE:
Hi from Portugal. I have got a mobo a8n-sli SE and im having trouble connecting my new wd 64mb 1gb green sata HD. I already have got 2 working hd´s, one IDE 128gb and one Sata 320gb and now i...
ur mother bios should support 1TB HDD, only then it ll get detected... u can update the bios of your motherboard with latest bios that is available for ur board in ASus support site...if you update the bios your hdd may get detected...
Sep 30, 2010 | ASUS A8N-SLI Motherboard
Does Asus A8N Sli Premium has any RS232 out connector ?
Externally no. Internally yes - lists a COM connector
Jan 09, 2010 | ASUS A8N-SLI Premium Motherboard
Boot usb cdrom a8n sli deluxe
Press Deleate key at boot enter bios goto boot settings set 1st boot devise as usb press F10 and enter to save changes
Nov 14, 2009 | ASUS A8N-SLI Deluxe Motherboard
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
ASUS EZ-PLUG not plugged in?
ASUS EZ_PLUG is optional for SLI mode...this model of your motherboard has an SLI that connect 2 video card using pci express...if this is only you problem for bugging the EZ_plug not connected,you can disable that in BIOS setup...
Oct 28, 2008 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI memory issues
imondeau, do you still have you're manual for the ASUS A8N-SLI Premium? Please turn to page 2-12 & 2-13.
Need the manual? Click the link below & download it.
http://support.asus.com/download/download.aspx?modelname=A8N-SLI%20Premium&SLanguage=en-us
The QVL; Qualified Venders List, shows all the tested memory for this board. Edge memory is not supported. This is why the Edge memory only runs by it's self. Once you add the corsair memory they clash because they are not compatible working together in this Asus board. Both sets of memory could work in another board. (Maybe)! What is also needed is if the corsair & edge DIMMs are SS = Single sided or DS = Double sided. How many chips on the corsair? How many chips on the Edge?
They must have the same total chips each each DIMM.
Edge does not sell memory compatible for the
Asus A8N-SLI Premium.
See this for you're self. Click on this link:
http://www.edgetechcorp.com/memory/
Mike
Jun 17, 2008 | ASUS A8N-SLI Premium Motherboard
Asus A8n-sli premium with amd 64 3700+ proc
Usally blue screen errors are from ram. Do you have the right ram for that board?. Is the ram set to the right speed in bios?.
Feb 28, 2008 | ASUS A8N-SLI Premium Motherboard
Asus A8N sli Premium - sli problems
I went through your bios manual three times & did not come across a setting that gives you the option as you listed above.
What I did come across & triple checked your Manual Pg. 2-28 section 14. Asus EZ selector card connector (144-pin SLI_CON.
When using two PCIE SLI cards make sure the card is seated correctly & set for Dual Video Cards. (extreamly important).
Pg. 4-34, section 4.4.9 SLI mode Recommend kepping to Auto. Than the Bios detects the setting of theSLI selector card.
Refering to the sentance above the manual recommends all settings be set to Auto. Your Bios will do the rest. If for unknown reason you no longer have your manual you can download it from Asus. You'll need to fill in the 3 windows under, Please Select the Product.
Motherboard
Socket939
A8N-SLI Premium
Any more question Drucos, please feel free to post back here!
& please vote...
Feb 22, 2008 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
Open Questions:
1855:536:5666+TWC Roadrunner Mail contact NumberTWC Roadrunner Mail Customer Service Phone NumberTWC Roadrunner Mail Customer Service Phone NumberGPSQTOA SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail Number SOLVE1855:536:5666+TWC Roadrunner Mail NumberTWC Roadrunner Mail TWC Roadrunner Mail Phone NumberTWC Roadrunner Mail TWC Roadrunner Mail Contact NumberTWC Roadrunner Mail TWC Roadrunner Mail Support NumberTWC Roadrunner Mail TWC Roadrunner Mail HelplineTWC Roadrunner Mail TWC Roadrunner Mail Tech SupportTWC Roadrunner Mail TWC Roadrunner Mail Customer SupportTWC Roadrunner Mail TWC Roadrunner Mail Customer SupportTWC Roadrunner Mail TWC Roadrunner Mail Toll Free NumberTWC Roadrunner Mail TWC Roadrunner Mail Technical Support NumberTWC Roadrunner Mail TWC Roadrunner Mail Service Phone NumberTWC Roadrunner Mail TWC Roadrunner Mail Phone NumberTWC Roadrunner Mail TWC Roadrunner Mail supportTWC Roadrunner Mail TWC Roadrunner Mail customer serviceTWC Roadrunner Mail TWC Roadrunner Mail Support NumberTWC Roadrunner Mail TWC Roadrunner Mail Customer Service Number contact Microsoft TWC Roadrunner Mail supportTWC Roadrunner Mail TWC Roadrunner Mail Tech Support Phone.
Aug 19, 2019 | Microsoft Computers & Internet
See all ASUS A8N-SLI Premium Motherboard Questions
ASUS A8N-SLI Premium Motherboard Logo
190 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
