SOURCE: Wireless Button Disabled
After one month of trying everything, I finally figured this one out. First turn off and restart your computer. Then press F10 to enter the System BIOS Settings. Select F9 (Setup Defaults) and when it asks Load Default Configuration Now? , Enter YES. Then, press F10 (Save and Exit) and when it asks Save Configuration Changes And Exit Now, Enter YES. This should restore the wireless LAN button to its original factory settings. Once you restart the computer the button will be listed as disabled, but press on the button and it should work again. I hope this helps someone else out!
SOURCE: HP Pavilion tx 2000 touchpad problems
Ok,The setting for the touch pad are not in the mouse settings,They are in the pen and input settings.
Just go to the control panel and select Pen and Input setting and adjust as needed.
Also with Vista,Windows tries to control everything,so you may need to un install the mouse drivers and allow windows to take control,It will not prevent the touch pad from working,It just stops it from being controlled by the touch pad driver and the windows mouse driver ar the same time.
SOURCE: Mouse Buttons on Compaq Presario V3000 Don't Work
Might need to take it apart and clean them. Did you spill something in there? Also make sure your mouse properties are set right click speed etc) in Control Panel. Can you double-tap the touchpad to make selections.
SOURCE: Mouse stopped working on Compaq Presario CQ57
The Touch pads the Mouse Pointer uses is pressure sensitive and sometimes without warning WILL fail to work I own a CQ50 And Have a On Off Option for the mouse pad Yours does not Apparently it Is a bad sensor If you have a warranty send it in If not best suggestion for you is buy a USB mouse and use it Otherwise trying to have it replaced without a warranty can be costly.
Testimonial: "Thanks for your help! No, that computer doesn't have an on/off button for the mouse pad like the previous model (I own both). I will try a plug in mouse and see if that works; if not, I will have to send it in for repair. Thank you again for helping me out!"
