50" projection tv
No power in tv. wall outlet has power. no power light on tv.
    President:
  • 3,130 Answers
That's like asking why won't my car start? We need a little more info on this please. Like a model number and make of the set and how old it is. Sorry my magic lamp and crystal ball does not work today.
Posted on Oct 02, 2007
"panasonic pt 50dl54 50 in rear screen does no show a picture
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 13, 2013 | Panasonic PT-50DL54 50" Rear Projection...
No Picture/No Sound
This is very possibly a power surge, can you tell me how many times the light blinks, you probably have a bad power board now if you had a power surge.
Aug 11, 2007 | RCA HD52W59 HDTV Projection Television
TV will not come on, LED light flashes 10 times, then pauses, then repeats Sony Model KDP 57ws655
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 21, 2010 | Sony Grand WEGA KDP-57WS655 57" Rear...
Tv set will not come. blink 5 time .model fds 50a2000
Jul 19, 2010 | Sony KDS-50A2000 50" HDTV
Standby light flashing
Jul 18, 2010 | Sony KP-53V45 53" Rear Projection...
Turn on tv and standby light flashes 6 times
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue.
Follow the steps below to perform a power reset:
  1. Turn off the television.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Source
Oct 16, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
I have a sony kdsr50xbr1 screen turns off after 15 min, there is still sound but the screen is essentially blank. Sometimes there are bars on the side of the screen for a second. The the status light...
Hi!
Please try disconnecting all the cables from the TV then reconnecting them back after a few minutes. You may also try connecting the power cord from the TV directly to a functional wall outlet. If the issue persists then the projection lamp needs to be replaced.
Aug 27, 2009 | Sony KDSR50XBR1 50" Projection HDTV
My new Samsung 50
well is the outlet on wall bad ? or is the tv not getting power ./
Oct 07, 2008 | Samsung HLN5065W 50" Rear Projection...
Sony kf50xbr800
juzz i suggest that u would unplug the unit for a couple of minute the plug it back in on a wall outlet.use the tv/video button to change the video input if that button didnt work it may require service....jake
Dec 07, 2006 | Sony Grand WEGA KF50XBR800 50" Rear...
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
