AW-G170A Hello, I have tried to burn dvd-r and dvd+r medias with k3b on a linux machine. It seems like it keeps failing at one moment or another during the burning. It succeded only once, on a dvd+r media, but then, I count tens of failures. What I see in the log is that : 1. System 2. ----------------------- 3. K3b Version: 1.0.3 4. 5. KDE Version: 3.5.6 6. QT Version: 3.3.8 7. Kernel: 2.6.17-14mdv 8. Devices 9. ----------------------- 10. SONY DVD RW AW-G170A 1.62 (/dev/hdd, ) [CD-R, CD-RW, CD-ROM, DVD-ROM, DVD-R, DVD-RW, DVD-R DL, DVD+R, DVD+RW, DVD+R DL] [DVD-ROM, DVD-R s?quentiel, DVD-R double couche s?quentiel, DVD+R double couche ? saut, DVD-RAM, DVD RW ? r?inscription limit?e, DVD-RW s?quentiel, DVD+RW, DVD+R, DVD+R double couche, CD-ROM, CD-R, CD-RW] [SAO, TAO, RAW, SAO/R96P, SAO/R96R, RAW/R16, RAW/R96P, RAW/R96R, R?inscription restreinte, Saut de couche] 11. 12. Burned media 13. ----------------------- 14. DVD+R 15. 16. Used versions 17. ----------------------- 18. growisofs: 7.0 19. 20. growisofs 21. ----------------------- 22. Executing 'builtin_dd if=/dev/fd/0 of=/dev/hdd obs=32k seek=0' 23. /dev/hdd: "Current Write Speed" is 16.4x1352KBps. 24. 0/1367474176 ( 0.0%) @0x, remaining ??:?? RBU 100.0% UBU 0.0% 25. 0/1367474176 ( 0.0%) @0x, remaining ??:?? RBU 100.0% UBU 0.0% 26. 0/1367474176 ( 0.0%) @0x, remaining ??:?? RBU 100.0% UBU 0.0% 27. 0/1367474176 ( 0.0%) @0x, remaining ??:?? RBU 100.0% UBU 0.0% 28. 0/1367474176 ( 0.0%) @0x, remaining ??:?? RBU 100.0% UBU 0.0% 29. 0/1367474176 ( 0.0%) @0x, remaining ??:?? RBU 100.0% UBU 0.0% 30. 917504/1367474176 ( 0.1%) @0.2x, remaining 670:14 RBU 100.0% UBU 3.2% 31. 9142272/1367474176 ( 0.7%) @1.8x, remaining 74:17 RBU 100.0% UBU 45.2% 32. 36044800/1367474176 ( 2.6%) @5.8x, remaining 20:18 RBU 100.0% UBU 87.1% 33. 67600384/1367474176 ( 4.9%) @6.8x, remaining 11:51 RBU 100.0% UBU 87.1% 34. 99647488/1367474176 ( 7.3%) @6.9x, remaining 8:28 RBU 100.0% UBU 51.6% 35. 132153344/1367474176 ( 9.7%) @7.0x, remaining 6:41 RBU 100.8% UBU 32.3% 36. 153518080/1367474176 (11.2%) @4.6x, remaining 6:11 RBU 100.0% UBU 74.2% 37. 186843136/1367474176 (13.7%) @7.2x, remaining 5:15 RBU 100.0% UBU 87.1% 38. 220626944/1367474176 (16.1%) @7.3x, remaining 4:35 RBU 100.8% UBU 87.1% 39. 254935040/1367474176 (18.6%) @7.4x, remaining 4:08 RBU 100.8% UBU 87.1% 40. 289734656/1367474176 (21.2%) @7.5x, remaining 3:43 RBU 100.0% UBU 87.1% 41. 325025792/1367474176 (23.8%) @7.6x, remaining 3:22 RBU 100.0% UBU 87.1% 42. 360841216/1367474176 (26.4%) @7.8x, remaining 3:06 RBU 100.0% UBU 80.6% 43. 397049856/1367474176 (29.0%) @7.8x, remaining 2:51 RBU 100.0% UBU 87.1% 44. 433815552/1367474176 (31.7%) @8.0x, remaining 2:37 RBU 100.0% UBU 87.1% 45. 471040000/1367474176 (34.4%) @8.1x, remaining 2:26 RBU 100.0% UBU 87.1% 46. 508690432/1367474176 (37.2%) @8.1x, remaining 2:15 RBU 100.8% UBU 87.1% 47. 540573696/1367474176 (39.5%) @6.9x, remaining 2:06 RBU 100.0% UBU 87.1% 48. :-[ WRITE@LBA=40890h failed with SK=4h/ASC=08h/ACQ=03h]: Input/output error 49. :-( write failed: Input/output error 50. /dev/hdd: flushing cache 51. /dev/hdd: closing track 52. /dev/hdd: closing disc 53. 54. growisofs command: 55. ----------------------- 56. /usr/bin/growisofs -Z /dev/hdd=/dev/fd/0 -use-the-force-luke=notray -use-the-force-luke=tty -use-the-force-luke=tracksize:667712 -dvd-compat -speed=16 -use-the-force-luke=bufsize:32m This happens in every situation, when the computer is up since a long time or just booted, when it runs a program using a lot of I/O at once or not. It doesn't seem that it's related to the burner only, but I do not see how to fix the whole situation. Thank you for your help.
  • Gasolin Oct 01, 2007
    Actually I did found out a solution.
    Most of the IDE burners need to be set as secondary, master, in order to avoid CRC errors or failures during the burning. In linux, it would be /dev/hdc so.
    When I did that, I could burn again the dvds without any failure. There was an "hesitation" at the same point at the last time (where it always failed), but then, the burnfree perfectly worked and went through.
    I hope this helps a little bit.
The only way to get rid off this problem is "throw your dvd-r/w in street garbage collector can". :-)
Posted on Jan 27, 2008
Ok I have a Gateway Laptop model NV73A06u and it is not powering on. The computer is no booting up correctly. I tries to start and then fails. The computer tries to fix itself for a long time and nothing...
Have you tried a Live CD?
Since you have a newer model, you can try the latest Ubuntu release located here.
Download the .iso file.
Burn the .iso file to a CD or DVD.
For burning .iso files to media, I like ImgBurn for Windows ( ) and plain K3B for Linux.
Once the disk is burned, pop it in and make your machine boot from the Optical Drive (CD/DVD Drive).
Hit enter a few times once you are asked about the preferred language and to try Ubuntu without changes to your computer.
From there it should either boot up okay (maybe without sound because sound is iffy in Linux) or it will continue to be all kinds of badness.
The thing is at this point you should be able to tell if it is most likely hardware or software. If Linux boots up off of your disk, your Windows installation is hosed (not so bad, possibly cheap to fix). If you can't even boot into a Linux live environment, then the fix may involve money and a fair amount of screwdriver action.
-Brad Chesney
Jan 27, 2011 | Gateway Computers & Internet
I had Sony dvd rw AW-G170A. It can read cds and dvds sucessfully. When i burn cd it works fine and burnt successfully. But when i burnt dvd it shows following error.power calibration error writing short...
you might want to try and update the firmware on the DVD burner, find out with the vendor if there is a fw version and how to do it, if not I would suggest hiring a professional.
Dec 17, 2017 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
ITune fails to burn Cd on Sony AW-G170A Error 4280
It appears that lots of laptops need new hardware from the manufacturer - this should be available to download on their respective websites
Sep 06, 2009 | Sony DW-G120A DVD RW Dual Layer Burner
Windows XP with SONY RW-AW-G170A DVD Rewriter.Unable to format UDF on DVD disc even after disabling-in built CD burning engine.Formatting starts fine but after afew minutes alert message appears:...
May 19, 2009 | Microsoft Windows XP Professional
it very well could be the disc themselves, some computers like i certain kind better, my husbands only likes sony dics, wont burn on anything else, try that it might solve the
Problem with sony dvd rw aw-g170a
Hi i have Sony AW-G170A on 2 pc's and almoust at same period both pc's started not to read DVD cds, cds that were writen by the same drive so ive check the net and end up updating the Firmwares 1.71 to 1.75 so check this link. And get AW-G170A Firmware 1.75 then u gonna need Binflash to update the Firmware get Win32 GUI version if u use Win Xp. Open the program press Flash find the location of the 1.75 Firmware and update it restart pc and it should work it worked for me.
Jul 31, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
plz sum 1 gimme the link to download SONY DVD RW AW-G170A firmware.
Mar 28, 2008 | Computers & Internet
hi dear
the drivers are part of windows
what they look as though they did was rerun the m/board setup disk and install the m/board drivers
try removing the upper and lower filters
scroll down to how here
check for a firmware update
the laser may be dirty or has gone
try the drive on another computer
for firmware , here
Mar 24, 2008 | Computers & Internet
This is a problem with the DVD Writer model. SONY DVD RW AW-G170a has problems reading DVD+/- R/RW Discs. But there is no problem with any of the DVD+/- R/RW Dual Layer, DVD Ram or CD+/- R/RW Discs. It is the reason that this DVD Writer lacks the correct bitsetting for DVD+/- R/RW Discs. There is nothing else you could do other than replacing the wirter with some other model.
Aug 01, 2007 | Sony (1-796-293-13) Plug-In Module DVD...
NEC-3520A Suddenly stop to burn correctly, but reads OK
Have you tried lowering the burn/erase speed? To begin, simply do what you need to do on the lowest speed, and then keep increasing until it gives the error again. This will most likely work. I had this problem and I burn now CDs at 16x.
Jun 11, 2007 | NEC (ND-3520A-KIT-BLU) Burner
Computers & Internet Logo
228 people viewed this question
David Payne
David Payne
