Question about Adobe Photoshop CS2 for PC
Having less knowlage in image cutting
Running film designer studio in mumbai even iam very week in image cutting espiciely in hairs of the images presently iam working on photoshop 7
  • balakrishna Oct 01, 2007
    how to get solution fo my problume
hair cutting is a big chalange everyone face.
2day I found a good tut on this.
try link give bellow
your response at will be appriciated.
Posted on Oct 13, 2007
  • hakuraja Oct 13, 2007
    one more thing, for cutting any other shape best sol is to use pen tool to make a path and by activate selection of path go to invert selection n just click del key to remove unwanted parts.
Design studio trial mode with monthly access?
No, you need to input the serial number of the product to access all features. That was supplied when you purchased it.
Jan 28, 2017 | The Computers & Internet
How do I use the Artbooking cartridge on the cricut design studio?
Cricut design studio is no longer supported by Cricut but if you mean Cricut Design Space then this is how you do it. Open and sign in to Design Space select insert images and in the box on the right select my Image sets and then type in Artbooking. Artbooking cartridge will then come up for you to select what you want. all images come onto the mat at 2.5 inches they havent fixed this yet so you have to resize your images. If you want to download the image numbers from the artbooking book which go with design space go to and download the artbooking book from this lady please join her blog and leave her a message as she does a lot of work all of which she does for free. Also if you youtube cricut design space. or go onto design space in
Aug 20, 2014 | Cricut Expression Cutting Machine
Dropping frames during capture with Studio 12 Ultimate for Windows Vista
Hello , rozkr
This means the video quality settings are to high for your machine .
Reduce quality . Issue should be solved but image will be less sharp .
Best results for capturing video movies or tv programs are obtained with a stand alone DVD or Blu Ray recorder .
Regards ,
Mar 13, 2011 | Pinnacle Studio Plus 12 for PC
Corel video studio problem in xp service pack 2
I had the same issue with OTHER Corel products. I worked with it for a few days but finally, I just reinstalled the program and it has worked fine ever since.
Jul 19, 2010 | Corel Video Studio Pro X2 for PC
A dark line shows up through every scan. It is indistinct and shadowy, the same look as a hair stuck in your shutter would give in a film camera. It is perfectly straight and runs all the way from side to...
There is a 99% chance that there is a human/animal hair on the reader inside under the glass.
You should take a look with a flash light, if positive then open it to clean the system out.
Oct 12, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
Hair Selecting
If you are using Adobe Photoshop - try the background eraser tool.
Jun 28, 2009 | Adobe Computers & Internet
Trouble opening saved image move file in Pinnacle; "trouble finding the downloaded images"; frames seem to have lost the images. Can you help
go into your search box and type in the Pinnacle Studio plus 12, then search all files in your hard drive which should be ( C: drive), any thing with that name will come up then you click on all the files in that folder to look for your images.
Jun 08, 2009 | Pinnacle Studio Plus 12 for PC
My Cannon Rebel EOS 35mm film Camera is producing blank Film
If you are getting some photos where only part of the image is visible, then I suspect that they were photos where you used a flash.
Cameras have a specified maximum shutter speed for use with a flash, this is called its 'sync speed'. This is the fastest speed that the camera will need to open the lead shutter and close the trailing shutter in order to expose the entire surface area of the image and have it evenly lit by the flash unit. If you shoot too fast of a speed, then the shutter will only be partly completed its exposure and you'll get a photo with only part of the image showing. The faster the speed past the sync speed, the less the resulting area of the image. Most cameras will have a sync speed of 1/250 or less. I think a lot of the Rebel models are 1/90 - consult your manual.
Nov 23, 2008 | Canon EOS Rebel G 35mm SLR Camera
How to cut curled hair
I prefer Arcsoft studio, it came free with my scanner.
It is much easier to use for selecting areas, including
an intensity/hue matching Magic selection tool.
The automatic selection tool creates an approximate selection
border (Exact is virtually impossible). Once you have it, you
can zoom-in and then add or subtract areas for a better fit.
You can also easily invert, expand, shrink or smooth the selection polygon to get near perfect results.
The entire process should take about 10 minutes per image,
depending on complexity. I have once isolated over a hundred
animation puppets from a book that way.
Once you have created a perfect selection fence/polygon,
make sure that you have chosen the correct side of the
selection (inside/outside using the selection invert function),
and then use the fill/spill tool to fill the unselected area with
a repeatable solid (primary) color, that does NOT occur in
other parts of the image.
To do this correctly, set the FILL tool tolerances at max.,
since the fence controls what gets painted, not the underlying
Save the new image under a different file name.
You can now use the solid background color as a
"color key" or a mask for special effects or image
mixing. You may need several masks, positive and
negative to get the job done (using boolean logic)
e,g. image or black = image, ... etc.
PS another good tool that is astronomically cheaper
than photo shop is LView.
Jun 03, 2008 | Adobe Photoshop 7.0 for Mac
Adobe Photoshop CS2 for PC Logo
118 people viewed this question
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
