Replace a Fuse: 2007 Chevrolet HHR LT 2.2L 4 Cyl. (carcarekiosk.com) This has a video showing location of the engine fuse box.
Auto Parts by CarParts.com - Right Parts. Right Now.
Chevrolet HHR Repair & Service Manuals (35 PDF's (onlymanuals.com)
To replace the fuse box housing in your 2007 Chevy HHR LT 2.2, follow these steps:
Locate the Fuse Box: The fuse box is typically located in the engine compartment or under the hood. It houses various fuses and relays that control different electrical components in your vehicle.
Disconnect the Battery: Before working on any electrical components, disconnect the negative terminal of the battery to ensure safety.
Remove the Cover: Open the fuse box cover. You'll find a diagram inside the cover that shows the location and function of each fuse.
Identify the Faulty Fuse Box: Inspect the fuse box for any signs of damage or wear. If it's cracked, corroded, or malfunctioning, you'll need to replace it.
Unplug Electrical Connectors: Carefully unplug the electrical connectors attached to the fuse box. Take note of their positions to reconnect them correctly later.
Remove the Old Fuse Box: Unscrew or unclip the fuse box from its mounting bracket. Gently pull it out.
Install the New Fuse Box: Position the new fuse box in place and secure it to the mounting bracket. Reattach the electrical connectors.
Replace Fuses: Transfer the fuses from the old box to the new one. Make sure they match the correct positions as indicated by the diagram.
Test the Electrical Systems: Reconnect the battery and test all electrical systems (lights, radio, etc.) to ensure everything is functioning properly.
Secure the Cover: Close the fuse box cover and secure it in place.
Remember to consult your vehicle's manual or seek professional assistance if you encounter any difficulties during the process.
WENT TO "ALLDATADIY.COM" AND FOUND THE SCHEMATICS I WAS LOOKING FOR. YOU HAVE TO PAY FOR A SUBSCRIPTION, BUT IT WAS THE BEST $9.99 I EVER SPENT! THEY HAVE ALMOST EVERY REPAIR AND SERVICE MANUAL YOU CAN THINK OF.
