Question about ASUS P5LD2-VM Motherboard
Problem restrart pc /NO AUTORESTART
My asus mother board P5LD2-VM PROSESSOR FITTID 2.0 CORE 2 DUO INTEL A PROBLEM WINDOW START MESSEGE /CPU-V CODE FAILED /OVER VOLTAGE FAILED OVER C LOCKING FAILD.PLEASE SOLVE MY PROBLEM
  • Harsaran singh Oct 02, 2007
    MY MOTHER BOARD IS[P5LD2-VM]IAM INSTALLING PROCESSOR [INTEL CORE TM 2 DUO 2.0]PLEASE ADVISE WHETHER THE ABOVE ARE MATCHING IN MY COMPUTOR OR NOT THANKS
  • 21 Answers
It sounds like you're trying to overclock your CPU, and you have exceeded what the CPU is capable of, under the current conditions. When you start the computer, enter BIOS setup (e.g. press the DEL key), and adjust the CPU settings to default. If you're not sure how to do this, choose the "LOAD OPTIMAL SETTINGS" or "LOAD DEFAULT SETTINGS" option from the main BIOS menu. If you are not getting this error until after Windows has started, then there is software installed that is trying to overclock the CPU for you. Uninstall it. It may be a program provided by Asus, or may be a third-party program. It will probably have "tweak" or "overclock" in the name. Overclocking can achieve an increase in performance, but will void the warranty, and does reduce the lifespan of the parts, and tends to make Windows crash more often. It can cause immediate failure of the parts. It should only be done if you understand and accept the risks, and have decided the reward is worthwhile. For most users, it is not worth it.
Posted on Oct 02, 2007
    Problem Solver:
  • 10 Answers
The Core 2 Duo works fine with this board. You may need to flash the BIOS to a newer version for newer CPU type compatibility.
The 'Overclocking Settings Have Failed' message is an anomaly that I have seen on ASUS boards many times. It happens even when you are at default BIOS settings. It is most likely a Power Supply issue. Make sure your PSU is ATX 2.0 compliant. (Has the extra 4 connectors on the Mainboard power connector- not the extra 4-pin plug that feeds the CPU - the 24 pin main connector)
Posted on Oct 31, 2007
SOURCE:
Hi, I'm looking for Asus P5LD2-VM Dual-Core CPU Intel i945G chipset drivers that are compatible with windows 7. Please help....thanks for the support.
You can download the drivers from here (click here) or from here (click here_asus official website)
If you need further help, let me know with the name of the operating system installed on your computer.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | Ld Asus P5LD2-VM Dual-Core CPU Intel i945G...
Unable to shutdown the computer
it is the problem your computer operating system or motherboard bios setup problem . You restart your pc after restart then press dell key then prevew your bios setup option then choice bios defalt setup then press F10 press Y restart your pc .
Jul 21, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Is it compatible a intel dual core processor to a
Hi..
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Regards
PCmania
Jul 15, 2009 | ASUS P5PE-VM Motherboard
Can i use nvidia 8600 video card for my mother board asus p5pe-vm and processor intel core 2 duo to my motherboard
this are the CPU -s that you're mb can support (core 2 duo)the numbers after "All" are the bios version's you need for the cpu: Core 2 Duo E4300 (1.8GHz,800FSB,L2:2MB,65W,rev.L2) ALL 1201 Core 2 Duo E4400 (2.0GHz,800FSB,L2:2MB,65W,rev.L2) ALL 1202 Core 2 Duo E4500 (2.2GHz,800FSB,L2:2MB,65W,rev.M0) ALL 1406 Core 2 Duo E4600 (2.4GHz,800FSB,L2:2MB,65W,rev.M0) ALL 1406 Core 2 Duo E4700 (2.6GHz,800FSB,L2:2MB,revG0) ALL 1501 Core 2 Duo E6300 (1.86GHz,1066FSB,L2:2MB,rev.B2) ALL 0604 Core 2 Duo E6300 (1.86GHz,1066FSB,L2:2MB,rev.L2) ALL 1201 Core 2 Duo E6320 (1.86GHz,1066FSB,B2:4MB,rev.B2) ALL 1402 Core 2 Duo E6400 (2.13GHz,1066FSB,L2:2MB,rev.B2) ALL 0604 Core 2 Duo E6400 (2.13GHz,1066FSB,L2:2MB,rev.L2) ALL 1201 Core 2 Duo E6420 (2.13GHz,1066FSB,L2:4MB,rev.B2) ALL 1402 Core 2 Duo E6600 (2.40GHz,1066FSB,L2:4MB,rev.B2) ALL 0604 Core 2 Duo E6700 (2.66GHz,1066FSB,L2:4MB,rev.B2) ALL 0604 Core 2 Extreme X6800(2.93GHz,1066FSB,L2:4MB,revB2) ALL 0604 and for the graphic card ...no because you motherboard has the "AGP" interface and the nvidia 8600 has "PCI - express" interface as is described here: http://www.nvidia.com/object/geforce_8600_8500_tech_specs.html
Jun 14, 2009 | ASUS P5PE-VM Motherboard
Install 2003 service pack 2
i'm installing windows sever 2003 but i can't find driver of mainboard intel dg31gl (sound and audio). do the mainboard dg31gl support windows sever 2003?, how can i install ? Help me, please. what can i do if mainboard dg31gl don't support windows server 2003? my mail is [email protected]
Sep 19, 2008 | ASUS P5LD2-VM Motherboard
P5ld2-vm problem
go to "bios settings" by pressing "delete" key or F2 at the system start up time .. after going in to bios then search for the options load optimal defaults ....then save it and exit ..
after that restart ...
now have a check if your problem persists then the processor which you have choosed might not support the motherboard specification the frequency of the processor is higher than the specified rate .. check here for the details of the processor which supports your motherboard
Intel Core 2 Duo HH80557PG0332M BX80557E4300 E4300 1.8GHz,800FSB,L2:2MB,65W,rev.L2 1102 2.00G HH80557PG0332M BX80557E4300 E4300 1.8GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0412M BX80557E4400 E4400 2.0GHz,800FSB,L2:2MB,65W,rev.L2 1202 2.00G HH80557PG0412M BX80557E4400 E4400 2.0GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0492M BX80557E4500 E4500 2.2GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0562M BX80557E4600 E4600 2.4GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0642M BX80557E4700 E4700 2.6GHz,800FSB,L2:2MB,revG0 1401 2.00G HH80557PH0362M BX80557E6300 E6300 1.86GHz,1066FSB,L2:2MB,rev.B2 0901 2.00G HH80557PH0362M BX80557E6300 E6300 1.86GHz,1066FSB,L2:2MB,rev.L2 1202 2.00G HH80557PH0364M BX80557E6320 E6320 1.86GHz,1066FSB,B2:4MB,rev.B2 1202 2.00G HH80557PH0462M BX80557E6400 E6400 2.13GHz,1066FSB,L2:2MB,rev.B2 0901 2.00G HH80557PH0462M BX80557E6400 E6400 2.13GHz,1066FSB,L2:2MB,rev.L2 1202 2.00G HH80557PH0464M BX80557E6420 E6420 2.13GHz,1066FSB,L2:4MB,rev.B2 1202 2.00G HH80557PH0564M BX80557E6600 E6600 2.40GHz,1066FSB,L2:4MB,rev.B2 0901 2.00G HH80557PH0674M BX80557E6700 E6700 2.66GHz,1066FSB,L2:4MB,rev.B2
check the website given below for details :
http://www.cpu-upgrade.com/mb-ASUS/P5LD2-VM.html
thank you
rate my solution
Sep 10, 2008 | ASUS P5LD2-VM Motherboard
Supported cpu
Intel Core2 Quad Q6600,
1066 Front Bus Speed, 65 nm
Apr 26, 2008 | ASUS P5LD2-VM Motherboard
Sound Problem - Not working properly
Dear Sir,
* Check your system with best antivirus software with latest virus definiation
or try another software for MP3 & Video playing.
if the problem contineus reinstall your OS.
Thank You.
Feb 19, 2008 | ASUS P5LD2-VM Motherboard
Pc restart problem
Yes, your mobo Asus P5LD2-VM support CPUs with Conroe-core ("Core 2 Duo"). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5LD2-VM But for new CPUs strongly recommended use last BIOS version - 1401 from 2007/08/14. http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5LD2-VM/P5LD2-VM-1401.rar
Oct 03, 2007 | ASUS P5LD2-VM Motherboard
ASUS P5LD2-VM Motherboard Logo
196 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
