Home | Epson | Stylus Color 740 InkJet Printer | Epson 740 printer see...
Epson Stylus Color 740 InkJet Printer
Problem for Epson Stylus Color 740 InkJet Printer
Epson 740 printer seems totally dead, all lights are blinking.
By scottcelder on Apr 28, 2009
All lights (power, paper, and ink) are all blinking and the printer seems totally fried. I'm actually going to post a solution to this problem, since I figured it out today and I want to share the solution with others who are pulling their hair out — like I was.
Comments:
Apr 28, 2009
- Okay, so I found a solution to this online today. I was about to toss this formerly trusty Epson 740 printer in the trash. From what I learned online (link below), this model has an automatic shutoff after a certain amount of printing. (To necessitate a trip to an Epson-approved repairman for maintenance, or the purchase of a new printer, I guess). All lights start blinking and there's no communication etc. possible through the printer utility. Printer seems totally fried. Turns out there's a kind of code that will reset this counter without any real repair, and then the printer will come back to life. Here's what worked for me:
1) Turn off your printer, ensuring that the print head is at it’s home location and locked in place as normal; 2) Power off the printer at the wall or by removing the power cable, for at least 20 seconds; 3) When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer’s power switch was ‘on’ - switch it off and return to step 1; 4) Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down; 5) When the paper-out LED flashes, release the buttons; 6) Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button); 7) The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
To my great surprise, that actually worked for me. I had tried everything and I had written to Epson support, which was worthless. I'm mad at Epson Support, so I went through the trouble of posting this. I had some trouble between steps 5 and 6, by the way. Timing is key there, I think it only worked when I released both buttons and then immediately (like as fast as possible) hit the "Cleaning" (i.e. Ink) button. And I may have held that button down longer than directed above. Really hope that helps others. I was really frustrated. Here's the link the site where I found the solution — huge hat tip to 2Manuals.com , wherever you are. Thanks!
http://www.2manuals.com/reset_wip.php
Apr 28, 2009
- Hope comment above helps.
Apr 28, 2009
- Thanks a lot, me.
Best Solution
posted on Apr 28, 2009
Very Helpful)
scottelder
Rank: Apprentice
Rating: 99%, 10 votes
Already solved.
Was this helpful?
Yes
No
8 people thought this was helpful
Solution #2
posted on Jul 13, 2009
Not Rated)
jazzerp
Rank: Apprentice
Rating: 0%, 0 votes
This worked for me too.Thanks
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus Color 740 InkJet
Questions and Unsolved Problems for Epson Stylus Color 740 InkJet
Do you recommend Epson Stylus Color 740 InkJet Printer?
Answer
Answer
my epson 740 color printer does not work after several years
Answer
keep getting message jobs stopped and i don't know what to do
Answer
what should be the power supply if it happens that the fuse is ok?cause the power supply i'm using... (More)
Answer
Epson Stylus 740 - Black will not print. Cleaned several times, installed a new cartridge.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Epson Stylus Color 740 InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 482
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
