-   I've tried unplugging overnite to reset and when I plug it in, I hear a click like it is trying to come on but nothing but the red power light blinking. I also looked into the back panel "carefully" and checked the fuses which are OK. Is this set worth the fix?-   Bullittbird
My tv is a Toshiba 55H71 but this is the closest number i found to it. We are having problems with...
(More)
My tv is a Toshiba 55H71 but this is the closest number i found to it. We are having problems with ours having lines across the screen and the longer it is on the worse it gets. There are only two that run verticle and many that run horizontal. What can we go to fix this?
TV was flooded. Already cleaned and ready for re-assembly. We need a circuit diagram to check...
(More)
TV was flooded. Already cleaned and ready for re-assembly. We need a circuit diagram to check accuracy of reconnection.
picture in picture won't go away. Some button was pressed on the remote and now we can't remove it...
(More)
picture in picture won't go away. Some button was pressed on the remote and now we can't remove it no matter what we do. Even Toshiba customer service had no idea.
Have a red picture. Installed satellite tv and the problem started. Adjusted picture settings, but...
(More)
Have a red picture. Installed satellite tv and the problem started. Adjusted picture settings, but no fix.
