Question about Canon FAXPHONE L170 Plain Paper Laser
Double shadow image
When I print or copy, I get a second double shadow image that is 2/3 down the page. What is going on?
  • mlam Oct 02, 2007
    I have cleaned the laser unit as the manufacturer suggested but still get the faint image. What other solutions are there?
PLEASE CHECK THE CONTACT POINTS OF THE TONER CARTRIDGE AND ALSO THE CORRESPONDING CONTACTS OF THE MACHINE , CHECK THE CLEANING UNITOF THE DRUM ALSO, HAPPY FAXING OMNIPRESENT
Posted on Oct 02, 2007
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 171 Answers
YOU NEED TO CLEAN THE LASER UNIT happy faxing omnipresent
  • ike4699 Mar 31, 2011
    I have a similar problem. The center of the page prints very dark, and there's a shadow image that runs about 3 inches down from the original image. I cleaned the drum in the toner cartridge (which was clean anyway) and the soft roller it makes contact with. What else do I need to do?
SOURCE:
How to copy 2 sided
If your printer does not have a duplex unit then the printer cannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn the page upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for the rest of the document.
I suggest you try a test page first, to get the printing the right way up on both sides of the page so it reads correctly.
Mar 31, 2013 | HP Office Equipment & Supplies
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
Samsung CLP-310 printer shadow printing on second half of page
I would check that the tension between your fusing rollers is ok as the toner will come off the paper and than return back to paper on its next revolution causing a faint image further down the page
May 19, 2012 | Samsung CLP 310 Laser Printer
Cleaning blade did not work
error code c00f0401 of my hp officejet v40 printer
Jan 07, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420 just started printing a shadow image
Sounds like a bad drum cartridge. Pull the toner/drum cartridge out of the machine and set it down. Press down on a (blue?) tab to release the toner cartridge, and you can lift the toner cartridge out of the drum cartridge. There is a cleaning blade in there - a soft plastic blade that rides against the drum and scrapes off toner that didn't get transferred to the paper. If it gets stuck off the drum surface, images repeat a few inches (one drum circumference) down the page.
A new DR-350 drum unit should fix it. have the machine's power on when replacing it. While the door is open, touch the CLEAR key. The display will read "REPLACE DRUM?" or something like that. Press 1 for Yes.
Jan 05, 2010 | Brother MFC 7420 All-In-One Laser Printer
Sharp AR 5320 printing a shadow copy
Shadow images may caused by several things :
1. Deformed rubber of the cleaning blade,
2. Drum aging,
3. Upper heater roller aging.
Jun 22, 2009 | Sharp Office Equipment & Supplies
Printer is making 2 copies instead of the requested one
when you go to print a page, click page setup, and change setting for copy's from 2 to 1...shia
May 22, 2009 | HP Photosmart C4280 All-in-One InkJet...
Showdowing on printed pages
Usually the Drum and the cleaning blade must be replaced together. Hope you done this already, if not replace the cleaning blade.
The problem can be in the fuser unit. Pleace check and replace the Hot roller, thermistor and HR strippers as a set and also the pressure roller bushings.
Dec 11, 2008 | Gestetner DSm622sp Digital Imaging System
Double sided printing Pixma MP520
here's how:
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Sep 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon FAXPHONE L170 Plain Paper Laser Logo
189 people viewed this question
Clive
Clive
old marine
old marine
Ekse
