Question about Pioneer DVR-520H DVD Recorder
Faulty hard drive
My hard drive has erased all pre-recorded programmes Now when i try to record it shows HDDERR or hard disc info is incorrect use disc setup menu to reinitialize (tried this but it didnt work
  • 3 Answers
Your hard drive needs to be replaced. They don't tell you in the operators manual, but these drives are extremely vulnerable to shock (even a 1/4" drop can kill them) and temperature change.
These machines are not sophisticated enough to mark bad sectors and work around them. Without a new hard rive, your machine will not work.
It is very unlikely, but there is a tiny chance you could reset the hard drive with a service remote. But considering how expensive and difficult it is to get a service remote, it is not worth the effort. You would also need a service manual, whic BTW is not particularly good, so you would need a lot of time and the chances of success are very small.
Considering repair costs, you may be better off financially to get a new DVR.
Posted on Aug 19, 2008
Recorded programmes from some channels break up- both the picture and sound- when replayed
I've got one. Does exactly the same thing. It usually happens within the first, say, 10 hours of recorded material. This is the most used part of the hard drive disc. We have 5-9 hours of programs we intend to keep so we end up re-recording over the next part of the disc repeatedly. This wears that part down. What I did was keep 2-3 hours of stuff in that zone and carried on recording and deleting as usual, as I still do. I'm watching it right now. But if I erase past the break 'zone', the recordings 'jump'. It has a big memory and shouldn't be a problem. So..........fill with programs to half the disc and record over the lesser used part of the disc.....it works for me. I'd be interested in hearing how you get on. Good luck Red.
Mar 04, 2015 | Humax PVR9300T HD DVR
Playback on recorded disk
The DVD has burned incorrectly and the data has likely corrupted somewhat to the point where the DVD player/writer can't read it. You may be able to watch it on your computer with a DVD drive. Try saving it to your computer, then erasing the disc and trying to record something short to it and play it back - if it plays back, it's likely to have been a recording problem, however, if you get the same problem, it may be a dodgy disc, a faulty DVD player/writer, or a format problem. Try this, in order left to right. Copy DVD to PC -> Erase DVD -> Record on DVD from TV -> Play back If plays back Erase DVD -> Continue as normal If not Buy DVD-RW (emphasis on the minus) -> Try using that If that works continue as normal, otherwise... Return the DVD player/writer under warranty for repair/replacement.
Sep 17, 2007 | iLO DVDR04
Machine will not recognise a new disc when trying to copy a recording
Did the previous machine show EXACTLY the same problem, or did that machine have another issue?
Regarding this one, does the DVD drive respond well to playback discs, such as commercial release DVDs, or DVDs recorded on other machines? Does it play back CDs OK? If it passes these tests, move on to-
I suggest trying to record on different discs - such as a DVD-RAM, or on a different brand of DVD-R, or DVD-Rs from a different batch to your current ones.
If the machine succeeds here, all good and well, if it fails at this point, it seems the machine is faulty and should be returned.
Oct 09, 2014 | Panasonic DMR-EX773 DVD Player/Recorder -...
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
On my free view box recorded programmes only play for 48 seconds then goes back to library page. sometimes picture freezes before returning.
have you tried formatting the disc and starting afresh as it sounds like the hard drive has become corrupted. Doing this usually sorts the problem out and allows you to watch programs again that you record. Please note it will erase all programs that you have on there!!!
If you found this info helpful please vote for me
Mar 12, 2011 | Televison & Video
My lg recorder will not delete progs !?
my l g hard drive recorder/dvd,suddenly would not delete programmes that i wanted to edit ,also the timeshift would not work,but i could still record ok,and i had a few hours space left on the hard drive .so i copied to disc my favourite stored programmes ,about 3 discs,and put them to one side .
i tried then to format the complete hard drive ,but it didnt do anything !so i put it on record for 7hours on sp,then i stopped recording, and tried deleting the programme straight away ,and it did !it also cleaned the hard drive empty ! the timeshift is ok and all else is ok ,so i fixed it witha bit of my logic !hope this helps someone one day !
Sep 22, 2009 | LG RH266 Recorder
Cannot get DVD recorder DVD 3470H to download from hard drive to a disc. The machine is about a year old and I'm using recordable DVD-R When I try to record onto the disc I get a screen which says the...
Hi Guys,
Thanks for the response.
I've solved the problem.
I was trying to download a programme that was too big from the hard drive to the disc.Once I inserted a divide in the progeamme everything worked Ok,
Cheers,
Dec 16, 2008 | Televison & Video
Sky Plus Planner shows message Please Wait and nothing happens. Cannot therefore play previously recorded programmes or record new ones.
try formatting your hard drive, you will loose all the saved programmes but it may fix ur problem.
follow instructions:
http://nice-design.co.uk/blog/sky-plus-system-fault-how-to-fix-faulty-sky-without-a65-callout-fee
Oct 28, 2008 | Televison & Video
Pansonic DMR-EH55 DVD Recorder,
hi, did you try thr hard reset? sreejith
Jul 24, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Pioneer DVR-520H DVD Recorder Logo
217 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
