Question about Kenmore 93361
Refrigerator problem refrigerator section is not cooling properly. The side by side freezer seems to be working properly.
  • 2 more comments
  • Anonymous Jan 25, 2009
    refrigerator side is not cooling,freezer is ok ,fan is running .no air coming out of cooling vent at top of fridge side.is there another fan?or could this possibly be a thermastat problem.
  • Anonymous Feb 26, 2009
    You guys are the BEST! Love this site! OK my Freezer door was left open a crack (for a day or two) and now the fridge is not very cold even though the freezer door has been closed properly for 2 days. So fridge not very cold but freezer is and there is frost build up on the freezers bottom half back wall. Can I fix this myself? How exactly?
  • Anonymous Mar 07, 2009
    what if there is no air flow out of the vent, what is the fix
  • avericon May 10, 2009
    We have frost on the back freezer panel, no air coming out of the refer side, but the fan is running in the freezer (and the freezer works). What do I do to troubleshoot beyond this?
  • 3 Answers
I just took mine apart and it turned out to be the air diffuser assembly. The freezer side cools to the set temp by running the compressor. the refer side cools by allowing freezer air in through the diffuser. It's a shutter assy. in the upper left corner. I took mine apart and there was a broken piece inside that is part of the shutter itself, positioned by a motor. Fixed it with epoxy but a new on is adround $70 if you are not keen on fixing small parts.
Posted on May 20, 2009
  • 473 Answers
3 most common things that cause this are a defrost problem (will notice frost build up on back freezer panel), bad evaporator fan motor (should hear fan running in the freezer), or bad damper (vent to the fridge section). If no frost and fan is running check for air flow out of the vent. It should be at the top of the fridge section.
Posted on Oct 05, 2007
SOURCE:
My RJ 523V-R refrigerator has worked perfectly for 8 years, but suddenly stopped cooling the fridge properly while the freezer seems ok. how can I fix this?
Often times their is a fan from the freezer section to the refrigerator section, of some brands of boxes. If the fan goes out, the refrigerator sections no longer cools.
May 23, 2014 | Electrolux Refrigerators
Fridge side not working, freezer side is fine.making weird noisr
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 23, 2011 | Kenmore 56983 Side by Side Refrigerator
Freezer side seems to work but the refrigerator side isn't
Sep 11, 2011 | Maytag Refrigerators
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
Iceream is not freezing
The temperature is not set to high cooling.First check the temperature setting.But if temperature is set right and still the ice cream is not cooling then .Problem relates to weak compressor. ------------- The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that ice cream is not freezing, so that means freezer is not freezing to its required temperature.------- This indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
Kitchenaid Side by side refrigerator section is not cooling the freezer is over cooling
SINCE THE FRESH FOOD SECTION GETS ITS COOLING BY AIR CIRCULATION FROM THE FREEZER, THERE MUST BE A RESTRICTION IN AIR FLOW SOMEWHERE. CHECK THE FREEZER EVAPORATOR AND FAN TO BE SURE THAT THE FAN IS RUNNING, AND THE EVAPORATOR IS NOT RESTRICTED WITH FROST. CHECK THE DAMPER OPENINGS FROM THE FREEZER SIDE TO BE SURE THEY AREN'T ICED OVER. IF IT IS AN ELECTRONIC CONTROL, CHECK THE THERMISTOR CIRCUIT FOR PROPER RESISTANCE. TECH SHEET INSTALLED BEHIND THE TOE PLATE SHOULD GIVE THAT INFORMATION.
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 93361 Logo
645 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
