Question about Philips PSS110/17 MP3 Player
How to open a pss110 - Philips PSS110/17 MP3 Player
I nead driver for Philips PSS110 USB DEVICE mp3 plaer
go to the web site what suported your addware and download it
Aug 28, 2009 | Philips PSS110/17 MP3 Player
Firmware
The firmware has corrupted.
Run the Philips Device Manager, installed from the driver CD.
Connect the PSS110 to the mains and PC, when the Philips Device Manager registers that the device is connected click on the Restore option, and follow the on-screen prompts.
This will format the device and replace the corrupted firmware.
NOTE: ANY TRACKS WILL BE DELETED
Apr 25, 2009 | Philips PSS110/17 MP3 Player
My PSS110 can not find the tracks that have been loaded on to it.
This device uses its own internal database to keep track of the files it can show. If you just copy files over the database won't be updated.
Get the free program "ShoqBox Buddy" and use the "rebuild database" function to tell the device about the new files you added.
Nov 17, 2008 | Philips PSS110/17 MP3 Player
Pss110/5 system problem
The PSS110 is not fully compatible with Vista.
You can download the Philips Device Manager for the PSS110 from:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=MP3_PLAYERS_CA&sct=SHOQBOX_SU&session=20080627080823_82.5.154.61&grp=PORTABLE_ENTERTAINMENT_GR&ctn=PSS110/05&mid=Link_Software&hlt=Link_Software
The software is not Vista compatible so you will have to run it on an XP machine.
Run the Device Manager and select the repair option. This will update the firmware and replace the system files.
Make sure the player is connected to the mains during this process.
Use the Philips Device Manager
Jun 16, 2008 | Philips PSS110/17 MP3 Player
Hi tere
You need to use Musicmatch Jukebox. This player also needs Windows XP and Windows Media Player 10 to work.
It is not compatible with Windows Media Player 11. If you have version 11 you will need to uninstall 11 to roll back to 10.
You can download the CD content here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=MP3_PLAYERS_CA&sct=SHOQBOX_SU&grp=PORTABLE_ENTERTAINMENT_GR&session=20080402051549_86.153.215.238&ctn=PSS110/05&mid=Link_Software&hlt=Link_Software
Apr 01, 2008 | Philips PSS110/17 MP3 Player
Help
Music Match cancelled in August 2007 - check Yahoo website for details - their fault, not Philips.
Mar 09, 2008 | Philips PSS110/17 MP3 Player
Hi there
Make sure you are using Windows XP and Windows Media Player 10.
Also make sure you have installed Musicmatch Jukebox from the product CD.
The PSS110 is not compatible with Vista or Media Player 11.
If you have Media Player 11, then uninstall to roll back to version 10.
Also, you need to make sure the player is showing as "GoGear" and not "Removable Drive".
If Musicmatch shows the player as "Removable Drive", go into the options menu and click devices. Click the dropdown menu showing "removable drive", and select "GoGear"
Pss110
i dont no how to put on music
Jan 26, 2008 | Philips GoGear ShoqBox PSS110
Philips PSS110/17 256 MB MP3 Player
Please refer to this quick start guide... http://www.p4c.philips.com/na4/p/pss110_17/pss110_17_qsg_aen.pdf ...or if you need extensive details download this userguide http://www.p4c.philips.com/na4/p/pss110_17/pss110_17_dfu_aen.pdf Also, for more details on this device, refer to the support page mentioned below http://www.usasupport.philips.com/productDocuments.html?ProductCode=PSS110/17&subCat=SHOQBOX_SU_US_CONSUMER Those are pretty easy to follow instructions. Just do the right steps. Cheers
Mar 14, 2007 | Philips PSS110/17 MP3 Player
Philips PSS110/17 MP3 Player Logo
64 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
